[Nek5000-users] Setting up solid elements with genbox
Tue Jun 19 21:02:17 CDT 2012
Hello Kyle,
I do not know much about the set up for your case, however I see an error
in the way the .box file is setup.
In a .box file, the points should be in an ascending order. Hence for the
following lines in the your .box file the points in y-direction should be
in the reverse order, i.e. start with -3.0 to -1.0.
Box lower fuel
-8   8                                           nelx,nely for Box
0 8 1.                                              x0,x1,gain  (rescaled
in usrdat)
-1.00 -1.04 -1.25 -1.55 -2.00 -2.45 -2.75 -2.96 -3.00     y0,y1,...,yn
  ,   ,   ,                                 bc's  (3 chars each!)
I  ,I  ,I  ,E                                 bc's  (3 chars each!)
Hope this helps.
Harish.
On Tue, Jun 19, 2012 at 6:16 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Thanks Justin. I did look at that example, and it is helpful (especially
> for setting up the boundary conditions in the .box file, which I have now
> adjusted to be blank for the fluid bc's in the solid domain).
> My issue is that I don't understand the general steps necessary to setup
> an arbitrary domain. Simply changing the dimensions in the .box file, and
> using the conj_ht.rea as the base .rea file like this:
> conj_ht.rea
> 2                      spatial dimension  ( < 0 --> generate .rea/.re2
> pair)
> 2                      number of fields
> Box fluid
> in usrdat)
> -1.0 -0.96 -0.75 -0.45 0.00 0.45 0.75 0.96 1.00     y0,y1,...,yn
> P  ,P  ,W  ,W                                 bc's  (3 chars each!)
> P  ,P  ,E  ,E                                 bc's  (3 chars each!)
> Box upper fuel
> in usrdat)
> 1.00 1.04 1.25 1.55 2.00 2.45 2.75 2.96 3.00     y0,y1,...,yn
> I  ,I  ,E  ,I                                 bc's  (3 chars each!)
> Box lower fuel
> in usrdat)
> and then using genbox, changing nelv, deleting the fluid bc's for elements
> greater than 64, using genmap results in the peculiar error when running
> nek:
>  setup mesh topology
>  WARNINGa: Detected non-right-handed element.
>  Number     129  C1-4: -0.4000E-01 -0.4000E-01 -0.4000E-01 -0.4000E-01
> This is with the latest repo (843). Maybe I am missing some necessary
> changes to the .rea file?
> Thanks,
> Kyle
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, June 19, 2012 3:17:21 PM
> Subject: Re: [Nek5000-users] Setting up solid elements with genbox
> Hi Kyle,
> Did you take a look at the conj_ht case in the examples folder? It has
> something pretty close to what you want.
> Justin
> On Tue, Jun 19, 2012 at 1:18 PM, < nek5000-users at lists.mcs.anl.gov >
> wrote:
> Hi all,
> I am attempting to setup a simple 2D conjugate heat transfer problem using
> genbox. I use the example "turbChannel" as my model. I want to setup a
> fluid box in between two solid boxes. Therefore, my 2DturbChannel.box file
> appears:
> base.rea
> 2 spatial dimension ( < 0 --> generate .rea/.re2 pair)
> 2 number of fields
> Box
> 0 8 1. x0,x1,gain (rescaled in usrdat)
> P ,P ,W ,E bc's (3 chars each!)
> Box
> P ,P ,E ,W bc's (3 chars each!)
> Box
> Running genbox on this file produces a .rea file with 192 fluid elements.
> I first try to change "nelv" in the .rea file to 64. Running genmap on this
> file produces a "PERIODIC MISMATCH" error, likely due to the 192 boundary
> conditions for the fluid field. So I then delete all of the boundary
> conditions for elements greater than 64 in the fluid (leaving thermal
> boundary conditions for all 192 elements). Genmap now works, but running
> nek with this .rea/.map combination gives the error:
> ERROR READING INITIAL CONDITION/DRIVE FORCE DATA
> ABORTING IN ROUTINE RDICDF.
> I thought that this procedure would work, given previous discussion on the
> problem of conjugate heat transfer in Nek5000 (
> http://lists.mcs.anl.gov/pipermail/nek5000-users/2010-February/000121.html). Perhaps I generated the .map file from the incorrect form of the .rea
> file? My question: is there a simple way to deal with solid elements in
> this configuration without using prenek?
> Thanks,
> Kyle
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120619/edf59a38/attachment.html>
