[Nek5000-users] Passive Scalar Initialization
Sun Jul 15 12:09:00 CDT 2012
Thanks for your hint. So, how can I reinitialize the PS after some
time? Should I call useric at userchk? And as I have two passive
scalars, how can I make sure that just one of them is initialized and
the other one and the flow field are read from the restarting fld file?
Thanks again.
Alireza
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi Alireza,
> You can alway reinitialize any field, so either start with or without,
> whichever is easiest.  If it's a long and expensive run (esp. from
> a passive scalar standpoint, for example if you have very low Pr), then
> you might choose to not carry the PS along till you get to your desired
> background flow state.  Otherwise, PS typically costs much less than the
> hydro, so carrying PS along is not an excessive burden and the setup
> and logistics overhead is sometimes easier just to deal with it at
> the outset.
> I hope this helps.
> Cheers,
> Paul
> On Sun, 15 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I want to start solving the passive scalar equation after the
>> background flow field has reached certain characteristics. Is it
>> possible to defer the solution of the passive scalar and then
>> initialize it at sometime t>0? In this case, should I include the
>> passive scalar boundary condition data in the rea and usr files
>> from the beginning?
>> Thanks for your help.
>> Regards,
>> Alireza
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
