[Nek5000-users] Using postx
Thu Jul 5 12:58:23 CDT 2012
Hi Rich,
This example is on [0,2pi]^2.  Because it is a verification study
for which we wish to test convergence, the geometry is rescaled in
the .usr file (see routine usrdat) to get full 64-bit precision.
If you go to:
http://nek5000.mcs.anl.gov/index.php/UG#Documentation
and click on Examples, you'll get a .pdf that describes
the problem (p.6).
Paul
On Thu, 5 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Okay, I made the header and got VisIt to read in a file. However, the
> spatial coordinates shown in VisIt are not correct. From the example menu,
> I use eddy_uv, a 2D problem that is defined on boundaries [0,1] for x and
> [0,1] for y.  You can see this in the .box file and the .rea file.
> However, VisIt shows the domain as from [0,6.3] for both x and y, see
> attached figure. What is going on here?
> Rich
> Sent by: nek5000-users-bounces at lists.mcs.anl.gov
> 07/02/2012 07:33 PM
> Please respond to
> To
> cc
> Subject
> Re: [Nek5000-users] Using postx
> Hi Rich,
> You have to make a short header file that VisIt then opens.
> Aleks Obabko set up a how-to here:
> http://nek5000.mcs.anl.gov/index.php/VISIT#metata
> Aleks is gone, but I can help if you run into trouble.  Just email me
> personally and we can get it figured out (hchilds at lbl.gov).
> Best,
> Hank
> On Mon, Jul 2, 2012 at 3:43 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Paul
> Okay, so how do I use VisIt. I have version 2.4.0 on my PC. But it won't
> read any of the files from nek5000. Do I need to set some switch to enable
> a visit file?
> Rich
> 07/02/2012 03:27 PM
> Please respond to
> To
> cc
> Subject
> Hi Rich,
> Sorry about this.
> It turns out that most folks have been using VisIt for
> their analysis, so the incompatibility between postx
> and recent updates to file formats have generally not
> been an issue.
> I see from Katie's email that she's already working on
> an update to postx.
> Paul
> On Mon, 2 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Nek5-heads
>> I have run the example called turbChannel from the examples list and it
>> seemed to run fine. However, when I try to look at the results using
>> postx, I get the message
>> "PARAMETER DATA CORRUPTED OR MISSING FROM READ FILE"
>> as the post-processor exits.  I am also trying the do my own problem (a
>> DNS in a square duct) using turbChannel as an example. But I can't look
> at
>> my grid because I get the same message. What am I missing in the .rea
>> file?
>> Here is the turbChannel.rea file.
>> Rich Johnson
>> Idaho National Lab
> Nek5000-users mailing list
