[Nek5000-users] Using postx
Thu Jul 5 12:50:32 CDT 2012
Hi Rich,
Please, read the header of the file eddy_uv.usr
In this file geometry is remapped to 0 to 2 pi in usrdat2()
Let me know if you have other questions.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, July 5, 2012 11:46:53 AM
Subject: Re: [Nek5000-users] Using postx
Okay, I made the header and got VisIt to read in a file. However, the spatial coordinates shown in VisIt are not correct. From the example menu, I use eddy_uv, a 2D problem that is defined on boundaries [0,1] for x and [0,1] for y. You can see this in the .box file and the .rea file. However, VisIt shows the domain as from [0,6.3] for both x and y, see attached figure. What is going on here?
Rich
Sent by: nek5000-users-bounces at lists.mcs.anl.gov
07/02/2012 07:33 PM
Please respond to
To 	nek5000-users at lists.mcs.anl.gov
cc
Subject 	Re: [Nek5000-users] Using postx
Hi Rich,
You have to make a short header file that VisIt then opens.
Aleks Obabko set up a how-to here:
http://nek5000.mcs.anl.gov/index.php/VISIT#metata
Aleks is gone, but I can help if you run into trouble. Just email me personally and we can get it figured out ( hchilds at lbl.gov ).
Best,
Hank
On Mon, Jul 2, 2012 at 3:43 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
Paul
Okay, so how do I use VisIt. I have version 2.4.0 on my PC. But it won't read any of the files from nek5000. Do I need to set some switch to enable a visit file?
Rich
07/02/2012 03:27 PM
Please respond to
cc
Hi Rich,
Sorry about this.
It turns out that most folks have been using VisIt for
their analysis, so the incompatibility between postx
and recent updates to file formats have generally not
been an issue.
I see from Katie's email that she's already working on
an update to postx.
Paul
On Mon, 2 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Nek5-heads
> I have run the example called turbChannel from the examples list and it
> seemed to run fine. However, when I try to look at the results using
> postx, I get the message
> "PARAMETER DATA CORRUPTED OR MISSING FROM READ FILE"
> as the post-processor exits. I am also trying the do my own problem (a
> DNS in a square duct) using turbChannel as an example. But I can't look at
> my grid because I get the same message. What am I missing in the .rea
> file?
> Here is the turbChannel.rea file.
> Rich Johnson
> Idaho National Lab
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
