[Nek5000-users] Using postx
Mon Jul 2 18:00:19 CDT 2012
Hi Rich,
Great question -- I'm checking with Hank Childs
to see if 2.4.0 is up to date with the Nek5000 reader.
Also, I just noticed that the script we normally use
to generate a meta-data file is not in the repo.  It
should be shortly -- it's called "nekvis".  I usually
use it (on linux platforms) by simply typing
   nekvis
or
nekvis session
where session is the name of the .rea file.  This script
creates the metadata file and then launches VisIt. I'm attaching
the script that I use here, but Katie is putting the latest
into the repo.
Paul
On Mon, 2 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Paul
> Okay, so how do I use VisIt. I have version 2.4.0 on my PC. But it won't
> read any of the files from nek5000. Do I need to set some switch to enable
> a visit file?
> Rich
> Sent by: nek5000-users-bounces at lists.mcs.anl.gov
> 07/02/2012 03:27 PM
> Please respond to
> To
> cc
> Subject
> Re: [Nek5000-users] Using postx
> Hi Rich,
> Sorry about this.
> It turns out that most folks have been using VisIt for
> their analysis, so the incompatibility between postx
> and recent updates to file formats have generally not
> been an issue.
> I see from Katie's email that she's already working on
> an update to postx.
> Paul
>> Dear Nek5-heads
>> I have run the example called turbChannel from the examples list and it
>> seemed to run fine. However, when I try to look at the results using
>> postx, I get the message
>> "PARAMETER DATA CORRUPTED OR MISSING FROM READ FILE"
>> as the post-processor exits.  I am also trying the do my own problem (a
>> DNS in a square duct) using turbChannel as an example. But I can't look
> at
>> my grid because I get the same message. What am I missing in the .rea
>> file?
>> Here is the turbChannel.rea file.
>> Rich Johnson
>> Idaho National Lab
> Nek5000-users mailing list
#! /bin/tcsh
#  Shell script that generated VisIt metafile blah.nek5000 either from SESSION.NAME or from the first command line argument
 set nfld = 0					# # of field files
 if ($#argv == 0) then
    if (-f SESSION.NAME) then
       set base = `head -1 SESSION.NAME`	# case name
    else
       set nfld = -1				# exit
       echo
       echo '  No SESSION.NAME file -- Use "visnek case_name"'
       echo
    endif
 else
       set base = $argv[1]
 endif
if ($nfld != -1) then
 echo
 echo '  Generating '$base'.nek5000 file ...'
 echo
#echo 'endian little'			>  $base.nek5000
#echo 'endian big'			>  $base.nek5000
 if  (-e		        $base.fld01) then
    set nfld = `ls -1	        $base{.fld[0-9][0-9]*}			| wc -l`
    echo 'filetemplate:	       '$base'.fld%02d'			>  $base.nek5000
 else if (-e 		   'A0/'$base'0.f00001') then
    set nfld = `ls -1	     A0/$base{0.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	 A%01d/'$base'%01d.f%05d'		>  $base.nek5000
 else if (-e 		        $base'00.f00001') then
    set nfld = `ls -1	        $base{00.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	       '$base'%02d.f%05d'		>  $base.nek5000
 else if (-e 		  'A00/'$base'00.f00001') then
    set nfld = `ls -1	    A00/$base{00.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	 A%02d/'$base'%02d.f%05d'		>  $base.nek5000
 else if (-e 		        $base'000.f00001') then
    set nfld = `ls -1	        $base{000.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	       '$base'%03d.f%05d'		>  $base.nek5000
 else if (-e 		 'A000/'$base'000.f00001') then
    set nfld = `ls -1	   A000/$base{000.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	 A%03d/'$base'%03d.f%05d'		>  $base.nek5000
 else if (-e 		'A0000/'$base'0000.f00001') then
    set nfld = `ls -1	  A0000/$base{0000.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	 A%04d/'$base'%04d.f%05d'		>  $base.nek5000
 else
    set nfld = `ls -1		$base{0.f[0-9][0-9][0-9][0-9][0-9]}	| wc -l`
    echo 'filetemplate:	       '$base'%01d.f%05d'		>  $base.nek5000
 endif
 endif
 endif
 echo 'firsttimestep: 1'	 	>> $base.nek5000
 echo 'numtimesteps: '$nfld		>> $base.nek5000
#echo 'meshcoords: 1'			>> $base.nek5000
 echo
 echo ' Assuming that coordinates are in the first file '$base'*.f*01 -- otherwise edit $base.nek5000 file ...'
 echo
 echo ' Also one may need to correct for an endian by inserting the first line "endian big" or "endian little" in case of, e.g., files transfered from other systems'
 echo
 echo
 echo ' Total '$nfld' file(s) are in the generated file '$base'.nek5000 ... Done!'
 echo
endif	# nfld != -1
visit -o $base.nek5000
