[Nek5000-users] Corrupt mesh
Sun Jul 1 15:29:55 CDT 2012
Just wrap to several lines, making them shorter than
80 characters
Paul
On Sun, 1 Jul 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Alex,
> Related question to Mani's.  If one wanted to generate a box file
> explicitly giving the coordinates (as you suggested below), how should
> we span multiple lines in the .box file.  If we needed 100 elements in
> the wall normal direction, for example, that wouldn't fit on a single
> line.  I remember once trying to span multiple lines and genbox
> failed.
> Thanks,
> Josh
> On Sat, Jun 30, 2012 at 6:43 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Alex,
>> Thank you for checking.
>> Regards,
>> Mani
>> On 06/30/2012 05:24 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Mani,
>>> I got it -- you want to have boundary layers although it may be simpler
>>> just to give element coordinates explicitly in a single Box...
>>> Well, I generated .rea file from your .box file with repo version of
>>> genbox that looks fine in postx:
>>> http://www.mcs.anl.gov/~obabko/m1.tiff
>>> http://www.mcs.anl.gov/~obabko/m2.tiff
>>> Best.
>>> Aleks
>>> ----- Forwarded Message -----
>>> From: nek5000-users at lists.mcs.anl.gov
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Sent: Friday, June 29, 2012 6:08:57 PM
>>> Subject: Re: [Nek5000-users] Corrupt mesh
>>> Hi Mani,
>>> I am curious what is a reason for not using a single Box instead of your
>>> current strategy of 27 Boxes with uniform element distribution:
>>> 1:-8     -8     -8
>>> 2:-12     -8     -8
>>> 3:-8     -8     -8
>>> 4:-8     -12     -8
>>> 5:-12     -12     -8
>>> 6:-8     -12     -8
>>> 7:-8     -8     -8
>>> 8:-12     -8     -8
>>> 9:-8     -8     -8
>>> 10:-8     -8     -12
>>> 11:-12     -8     -12
>>> 12:-8     -8     -12
>>> 13:-8     -12     -12
>>> 14:-12     -12     -12
>>> 15:-8     -12     -12
>>> 16:-8     -8     -12
>>> 17:-12     -8     -12
>>> 18:-8     -8     -12
>>> 19:-8     -8     -8
>>> 20:-12     -8     -8
>>> 21:-8     -8     -8
>>> 22:-8     -12     -8
>>> 23:-12     -12     -8
>>> 24:-8     -12     -8
>>> 25:-8     -8     -8
>>> 26:-12     -8     -8
>>> 27:-8     -8     -8
>>> Thanks.
>>> Aleks
>>> ----- Original Message -----
>>> Sent: Friday, June 29, 2012 4:43:46 PM
>>> Subject: [Nek5000-users] Corrupt mesh
>>> Dear Nek devs,
>>> I am using genbox to construct a mesh for a box of aspect ratio 1 x 1 x
>>> 1. But for some reason, the mesh seems to be corrupted, from what I see
>>> in VisIt (screenshot attached). I have attached the .box file used to
>>> construct this mesh. Could you help diagnose the reason for this error?
>>> Thanks,
>>> Mani
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do
> nothing" -- Edmund Burke
