[Nek5000-users] Corrupt mesh
Sun Jul 1 11:11:53 CDT 2012
Alex,
Related question to Mani's.  If one wanted to generate a box file
explicitly giving the coordinates (as you suggested below), how should
we span multiple lines in the .box file.  If we needed 100 elements in
the wall normal direction, for example, that wouldn't fit on a single
line.  I remember once trying to span multiple lines and genbox
failed.
Josh
On Sat, Jun 30, 2012 at 6:43 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Alex,
> Thank you for checking.
> Regards,
> Mani
> On 06/30/2012 05:24 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Mani,
>> I got it -- you want to have boundary layers although it may be simpler
>> just to give element coordinates explicitly in a single Box...
>> Well, I generated .rea file from your .box file with repo version of
>> genbox that looks fine in postx:
>> http://www.mcs.anl.gov/~obabko/m1.tiff
>> http://www.mcs.anl.gov/~obabko/m2.tiff
>> Best.
>> Aleks
>> ----- Forwarded Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Friday, June 29, 2012 6:08:57 PM
>> Subject: Re: [Nek5000-users] Corrupt mesh
>> Hi Mani,
>> I am curious what is a reason for not using a single Box instead of your
>> current strategy of 27 Boxes with uniform element distribution:
>> 1:-8     -8     -8
>> 2:-12     -8     -8
>> 3:-8     -8     -8
>> 4:-8     -12     -8
>> 5:-12     -12     -8
>> 6:-8     -12     -8
>> 7:-8     -8     -8
>> 8:-12     -8     -8
>> 9:-8     -8     -8
>> 10:-8     -8     -12
>> 11:-12     -8     -12
>> 12:-8     -8     -12
>> 13:-8     -12     -12
>> 14:-12     -12     -12
>> 15:-8     -12     -12
>> 16:-8     -8     -12
>> 17:-12     -8     -12
>> 18:-8     -8     -12
>> 19:-8     -8     -8
>> 20:-12     -8     -8
>> 21:-8     -8     -8
>> 22:-8     -12     -8
>> 23:-12     -12     -8
>> 24:-8     -12     -8
>> 25:-8     -8     -8
>> 26:-12     -8     -8
>> 27:-8     -8     -8
>> Thanks.
>> Aleks
>> ----- Original Message -----
>> Sent: Friday, June 29, 2012 4:43:46 PM
>> Subject: [Nek5000-users] Corrupt mesh
>> Dear Nek devs,
>> I am using genbox to construct a mesh for a box of aspect ratio 1 x 1 x
>> 1. But for some reason, the mesh seems to be corrupted, from what I see
>> in VisIt (screenshot attached). I have attached the .box file used to
>> construct this mesh. Could you help diagnose the reason for this error?
>> Thanks,
>> Mani
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Josh Camp
"All that is necessary for the triumph of evil is that good men do
nothing" -- Edmund Burke
