[Nek5000-users] Most up to date build instructions?
Thu Jan 26 13:27:01 CST 2012
Hi Jay,
Yes .. you need SIZE in your working directory.
Each of the examples should have this... I recommend
copying the entire directory contents from an example
into your working directory.
Paul
On Thu, 26 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Paul,
> Thanks for getting back to me on this and sorry for the slow response.
> I had not modified the source path and fixing that at least got makenek
> started. I am now getting a message about incorrect usage. Running the
> following command from a build directory just below the source fails:
> ../makenek ../zero
> makenek - automatic build tool for Nek5000
> FATAL ERROR: Cannot find SIZE!
> Any thoughts?
> Jay
> On 01/23/2012 10:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Jay,
>> What was the failure stmt?
>> Did you modify the source path in makenek to point to the location
>> of your source ?
>> I just checked out the latest version and it seemed to work fine.
>> I modified the path since, in my case, I did not have this newest
>> version sitting in $HOME/nek5_svn/...
>> Please let me know if these suggestions help.
>> Regards,
>> Paul
>> On Mon, 23 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> Everyone,
>>> I recently downloaded Nek5000 and tried to build it following the
>>> instructions on the wiki, but it failed while running makenek. It appears
>>> that makenek, from looking at the script, no longer functions in the way
>>> described on the wiki. Are there updated instructions or a binary build
>>> available?
>>> Building on 64 bit RHEL-6.
>>> Jay
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
