[Nek5000-users] Add a forcing term on scalar equation
Fri Jan 20 10:12:21 CST 2012
Hi Iman,
There are some minor bookkeeping issues here...
Just to make certain we're on the same page, are you currently
using Pn-Pn-2, or Pn-Pn ?
Paul
On Fri, 20 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Paul,
> Numerically the momentum equation has an explicit forcing term.
> Only that, it is based on the T at the same time. However, I would like to first solve the equation for the scalar.
> In other words, I want to first solve the equation for T, use it to calculate f(T) and afterward solve the momentum equation ( u_t=NS + f(T) ). So How I can do that!?
> Iman
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Friday, January 20, 2012 2:25 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Add a forcing term on scalar equation
> Iman,
> These can be coupled explicitly, but not implicitly.   Usually, however,
> this is sufficent.  Equation are of the form:
>    u_t = NS +  f(u,T)
>    T_t = energy eq. + q(u,T)
> f & q explicit.   The code will take care of the bookkeeping.
> Paul
>> Thanks.
>> So I just used the "USERQ" to implement the forcing term to scalar filed explicitly.
>> In the next step, I want to coupled the scalar field to Navier-Stokes equation using a forcing term.
>> In this case, the forcing term is a function of scalar field and I would like to implement it implicitly.
>> As far as I know, if I used USERF, the scheme is explicit. So how can I add a forcing term to N-S equation implicitly!?
>> Iman
>> Sent: Thursday, January 19, 2012 4:20 PM
>> It's actually evaluated explicitly, so you shold be ok.
>> Paul
>> On Thu, 19 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi
>>> I would like to add a forcing term to the scalar equation.
>>> According to the Nekton manual, Chapter 5, the forcing term is treated implicitly and the convective term is integrated using the third order Adam_Bashforth scheme (AB3).
>>> For my case, the forcing term is a nonlinear function of the scalar field, so I cannot use the implicit scheme and I should lump it with the AB3.
>>> Therefore, could you please guide me and indicate where in the code I can find the implementation of AB3 for the convective term of passive scalar?
>>> Cheers
>>> Iman
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
