[Nek5000-users] Restart problem
Mon Jan 16 07:54:10 CST 2012
Hi Adam,
How many vectors do you intend to store in the restart file?
I think we can readily accommodate this.
Paul
On Mon, 16 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Hi
> I tested new restart both with and without projection and it works. What
> is the problem with passive scalars? I use them, but they are not
> crucial at this point. However, I thought to use them as storage for
> eigenvalues for my arnoldi implementation.
> Best regards
> Adam
> On Thu, 2012-01-05 at 03:13 -0600, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Do you have any passive scalars?
>> There are some issues w.r.t passive scalar i/o that we're working
>> to resolve.
>> Paul
>> On Thu, 5 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> On Thu, 2011-12-22 at 22:22 -0600, nek5000-users at lists.mcs.anl.gov
>>> wrote:
>>> Hi
>>> Thank you Paul. I've made short test with jet in crossflow and it seem
>>> to work, but I've got sometimes following warning
>>> WARNING: restart file has a NSPCAL > LDIMT
>>> read only part of the fld-data!
>>> WARNING: NPSCAL read from restart file differs from
>>> currently used NPSCAL!
>>> What's strange this warning doesn't show up at every restart. I'm going
>>> to make some longer tests now.
>>> Regards
>>> Adam
>>>>> Hi
>>>>> I simulate jet in crossflow problem with nek5000 and I've got serius
>>>>> problems with restarting the simulation. It causes strong spurious
>>>>> velocity oscillation and I cannot get rid of them. I've implemented
>>>>> restarting procedure described in prepost.f, but it doesn't help much.
>>>>> Playing with file format (parameters p66, p67) and projection (p94, p95)
>>>>> I can only decrease oscillations amplitude, but they are still there.
>>>>> Surprisingly saving output files in double precision (p63=8) makes
>>>>> everything worse. Has anybody got similar problems?
>>>>> Best regards
>>>>> Adam
>>>> Hi,
>>>> I think that the full restart capability should now work with
>>>> the current version of the source.
>>>> There is a 2D example in the repo, with a README that I also
>>>> provide below.
>>>> Basically, you will now save 4 files each time you wish to
>>>> checkpoint.  The files come in two sets, A and B, and the A
>>>> set is then overwritten by the 3rd checkpoint, etc. so that
>>>> you have at most 8 checkpoint files on hand at any one time.
>>>> The files are 64 bit and thus cannot be used by VisIt --- thus,
>>>> they are truly designated as checkpoint/restart files and not
>>>> analysis files.   More information in the README below.
>>>> Please let me know if you have comments or questions.
>>>> Best regards,
>>>> Paul
>>>>> From the examples/cyl_restart directory:
>>>> SET UP:
>>>> This directory contains an example of full restart capabilities for
>>>> Nek5000.
>>>> The model flow is a von Karman street in the wake of a 2D cylinder.
>>>> The quantity of interest is taken to be the lift, which is monitored
>>>> via "grep agy logfile" in the run_test script.   A matlab file, doit.m,
>>>> can be used to analyze the output files containing the lift history
>>>> of the four cases.  The cases are:
>>>> ca   -   initial run (no projection)
>>>> cb   -   restart run for ca case
>>>> pa   -   initial run (with projection)
>>>> pb   -   restart run for pa case
>>>> BACKGROUND:
>>>> Timestepping in Nek5000 is based on BDFk/EXTk (k=3, typ.), which uses kth-order
>>>> backward-difference formulae (BDFk) to evaluate velocity time derivatives and
>>>> kth-order extrapolation (EXTk) for explicit evaluation of the nonlinear and
>>>> pressure boundary terms.  Under normal conditions, the velocity and pressure
>>>> for preceding timesteps are required to advance the the solution at each step.
>>>> At startup, the timestepper is typically bootstrapped using a lower-order
>>>> BDF/EXT formula that, given the artificiality of most initial conditions,
>>>> is typically adequate.    The velocity field often has enough inertia and
>>>> sufficient signature such that the same bootstrap procedure also works when
>>>> restarting from an existing solution (i.e., a .fnnnnn or .fldnn file, stored
>>>> in 32-bit precision).
>>>> For some cases, it is important to have reproducibility of the time history
>>>> to the working precision (14 digits, typ.) of the code.  The full restart
>>>> feature is designed to provide this capability.   The main features of
>>>> full restart are:
>>>> .Preserve alternating sets of snapshots (4 per set) in 64-bit precision.
>>>>   (Alternating sets are saved in case the job fails in the middle of
>>>>    saving a set.)
>>>> .Use the most recent set to restart the computation by overwriting
>>>>   the solution for the first steps, 0 through 3, with the preserved
>>>>   snapshots.
>>>> Full restart is triggered through the .usr file.    In the given example
>>>> cases, "ca" and "cb" the restart-save is illustrated in ca.usr and the
>>>> actual restart, plus the save, is illustrated in cb.usr.   For these cases,
>>>> the restart is encapsulated in the user-provided routine "my_full_restart"
>>>> shown below, along with the calling format in userchk:
>>>> c-----------------------------------------------------------------------
>>>>        subroutine userchk
>>>>        include 'SIZE'
>>>>        include 'TOTAL'
>>>>        logical if_drag_out,if_torq_out
>>>>        call my_full_restart
>>>>        scale = 1.
>>>>        if_drag_out = .true.
>>>>        if_torq_out = .false.
>>>>        call torque_calc(scale,x0,if_drag_out,if_torq_out)
>>>>        return
>>>>        end
>>>>        subroutine my_full_restart
>>>>        character*80 s80(4)
>>>>        call blank(s80,4*80)
>>>>        s80(1) ='rs8ca0.f00005'
>>>>        s80(2) ='rs8ca0.f00006'
>>>>        s80(3) ='rs8ca0.f00007'
>>>>        s80(4) ='rs8ca0.f00008'
>>>>        call full_restart(s80,4)  ! Will overload 5-8 onto steps 0-3
>>>>        iosave = iostep           ! Trigger save based on iostep
>>>>        call full_restart_save(iosave)
>>>>        return
>>>>        end
>>>> Note that in the example above, the set enumerated 5--8 is used to restart
>>>> the computation.   This set is generated by first running the "ca" case.
>>>> Note that the frequency of the restart output is coincident with the
>>>> standard output frequency of field files (snapshots).  This might be too
>>>> frequent if one is, say, making a movie where snapshots are typically
>>>> dumped every 10 steps.   It would make more sense in this case to set
>>>> iosave=1000, say.
>>>> Note also that if one is initiating a computation from something other
>>>> than the full restart mode then the full_restart() call should be commented
>>>> out.
>>>> COMMENTS:
>>>> Full reproducibility of the solution is predicated on having sufficient
>>>> history information to replicate the state of "a" when running "b".
>>>> While such replication is possible, it does preclude acceleration of the
>>>> iterative solvers by projection onto prior solution spaces [1,2], since
>>>> these projections typically retain relatively long sequences of information
>>>> (e.g., spanning tens of steps) to maximally extract all the regularity in the
>>>> solution history.   Consequently, _full_ reproducibility is not retained with
>>>> projection turned on.  In this case, the solution is reproduced only to the
>>>> tolerance of the iterative solvers, which is in any case the maximum level
>>>> of accuracy attainable in the solution.   To illustrate the difference,
>>>> we provide a test case pairing, "pa" and "pb", which is essentially the
>>>> same as the ca/cb pair save that projection is turned on for pa/pb.
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
