[Nek5000-users] Anisotropic conductivity
Wed Aug 1 16:52:14 CDT 2012
Thanks for your hints. I wonder if you could help me extending the
case you sent me to 3D. Also, I have difficulty understanding the 2D
example. For instance, what quantities does the array kxy represent?
And how this procedure can be simplified for constant diffusion
coefficients?
Best Regards,
Alireza
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi Alireza,
> There is a paper on my website describing the approach:
> http://www.mcs.anl.gov/~fischer/pubhtml/fischer_sci05.pdf
> Basically, you need to change the geometric factors after
> nek has set them.  I normally do this in userchk, because
> the first call to userchk implies that the code is ready
> to start solving the equations and that (most) all of the
> requisite variables are set.    Therefore, if you change
> them, they won't be reset against your wishes.
> (This is trickier if you have ifuservp=.true.,
> because in that case nek will keep resetting the diffusivity...,
> but maybe it will be ok---we can look into that.)
> I can send an example where I've set up anisotropic diffusion
> problem... (attached here, in fact, but I've
> not tested recently).  It's a 2D case.
> Let me know if you need assistance with the 3D case or have
> questions with this one -- the only tricky part is figuring out
> where the components of the symmetric 3x3 tensor are stored.
> Best regards,
> Paul
> On Tue, 26 Jun 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I want to solve for a convective heat transfer problem with a
>> diagonal conductivity tensor which has different constant values in
>> x and y directions. I assume I should use udiff, but I'm not sure
>> how to implement it. I wonder if you have any idea.
>> Regards,
>> Alireza
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
