[Nek5000-users] Problem with restart option
Mon Apr 23 10:44:42 CDT 2012
Thanks guys,
using the mpif90-wrapper solved the problem.
Best wishes,
Alex
On 23.04.2012 17:41, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Alex,
> Not sure if this is a compiler related problem as stated by Fabian.
> That question to answer is the following:
> It looks like the read statement at 2255 at ic.f fails, that's why we
> jump into the parser of the old header (by mistake). This results in
> mess the code expects a different format of the header. That's why you
> get the integer division by ZERO.
> Cheers,
> -Stefan.
> On 4/23/12, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov>  wrote:
>> Dear Jens and Alex,
>> try to use "mpif90" instead of "mpif77". The "mpif77" configuration on
>> rz cluster is broken...
>> Kind regards,
>> Fabian
>> On 04/23/2012 04:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi neks,
>>> I'm having some problems with the restart feature in the version 803
>>> of Nek5000. When I want to restart from a field-file, I get a warning
>>> saying "WARNING: reading depreacted header!" and my program crashes
>>> because of a division by zero. The file I use for my restart is from
>>> the same version of Nek5000 and the header looks like
>>> "#std 4  8  8  8      29016      29016  0.2500539468005E+02
>>> 2554      0      1 UPT  "
>>> followed by bytes. Nek5000 has been compiled with Intel compilers
>>> (version 12.1.3) and OpenMPI (version 1.5.3). Is there something I'm
>>> missing?
>>> Best regards
>>> Alex
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
