[Nek5000-users] Problem with restart option
Mon Apr 23 10:41:59 CDT 2012
Hi Alex,
Not sure if this is a compiler related problem as stated by Fabian.
That question to answer is the following:
It looks like the read statement at 2255 at ic.f fails, that's why we
jump into the parser of the old header (by mistake). This results in
mess the code expects a different format of the header. That's why you
get the integer division by ZERO.
Cheers,
-Stefan.
On 4/23/12, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Jens and Alex,
> try to use "mpif90" instead of "mpif77". The "mpif77" configuration on
> rz cluster is broken...
> Kind regards,
> Fabian
> On 04/23/2012 04:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi neks,
>> I'm having some problems with the restart feature in the version 803
>> of Nek5000. When I want to restart from a field-file, I get a warning
>> saying "WARNING: reading depreacted header!" and my program crashes
>> because of a division by zero. The file I use for my restart is from
>> the same version of Nek5000 and the header looks like
>> "#std 4  8  8  8      29016      29016  0.2500539468005E+02
>> 2554      0      1 UPT  "
>> followed by bytes. Nek5000 has been compiled with Intel compilers
>> (version 12.1.3) and OpenMPI (version 1.5.3). Is there something I'm
>> missing?
>> Best regards
>> Alex
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
