[Nek5000-users] genmap error: "infinite loop"
Mon Sep 12 07:56:51 CDT 2011
Hi Paul,
Thanks for explaining the error.
Mani
On Mon, Sep 12, 2011 at 3:59 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mani,
> It's not a fatal flaw... particularly for the values shown.
> It simply means that recursive spectral bisection could not
> find a split that would yield connected subgraphs in the
> domain partitioning scheme.   At the leaves of the graph
> (indicated by the small values 1 2 1), this is not a big
> deal.  Elsewhere, it could be detrimental to performance,
> but the code would still run correctly.
> Paul
> On Sun, 11 Sep 2011, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Dear Nek devs,
>> I get the following error when using genmap to generate the .map file from
>> a
>> mesh involving a large number of elements, in this case 157464 elements.
>> infinite loop
>> not connected           1           2           1           0
>> I have attached the full log file from genmap along with the .box file
>> used
>> to generate the mesh. How does one fix this error?
>> Thanks,
>> Mani
>>  ______________________________**_________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110912/df27f721/attachment.html>
