[Nek5000-users] Modifying an initial field
Wed Oct 5 15:20:01 CDT 2011
Hi Josh,
Yes, changing the initial field in the first call of userchk worked, thanks.
David
On Tue, Oct 4, 2011 at 6:21 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi David,
> The best place would probably be in userchk.
> You could have a block like
> if (istep.eq.0) then
> C........do stuff
> endif
> If you are doing something else in userchk that would depend on your
> modification of the field quantities, then you would want  this to come
> first.
> Just in case, the velocity fields are accessed like
> vx(i,j,k,e) ( for u)
> and likewise for vy and vz, where i,j,k go from 1 to nx1 (ny1, nz1) and e
> goes from 1 to nelv.  Sorry if that was more information than you needed,
> just wanted to make sure all my bases were covered :-).
> Does this help?
> Josh Camp
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111005/c16706a3/attachment.html>
