[Nek5000-users] Calculation of Divergence Term
Sat Nov 12 11:26:11 CST 2011
No problem... sorry for the delay in getting you what you needed.
On Sat, 12 Nov 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Thanks a lot for your hints and I appreciate your help. Sorry for
> interrupting when you were so busy.
> Regards,
> Alireza Karimi
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Dear Alireza,
>> You would add this to qvol, since it is the convection-diffusion
>> equation -- so, the routine is userq.
>> You should precompute the term in userchk, store the result in
>> a common block, and then dereference in userq.   Expanding on Josh's
>> suggestion below you would have something like
>> c-----------------------------------------------------------------------
>>      subroutine userchk
>>      common /mydiv/ divcv(lx1,ly1,lz1,lelt)
>>      common /scrns/ dcv1dx(lx1,ly1,lz1,lelt)
>>                   , dcv2dy(lx1,ly1,lz1,lelt)
>>                   , dcv3dz(lx1,ly1,lz1,lelt)
>>                   , work1 (lx1,ly1,lz1,lelt)
>>                   , work2 (lx1,ly1,lz1,lelt)
>>        then his calls... be sure to define n
>>      return
>>      end
>>      subroutine userq  (ix,iy,iz,eg)
>>      include 'SIZE'
>>      include 'TOTAL'
>>      include 'NEKUSE'
>>      integer e,f,eg
>>      e = gllel(eg)
>>      qvol = divcv(ix,iy,iz,e)  Be sure to check the sign of this term
>>      return
>>      end
>> It's not a priori clear that you need to dealias this term.
>> Dealiasing is needed in certain circumstance for stability -- it
>> does not materially affect accuracy.  Without further context
>> I cannot tell you whether you need to dealias or not.
>> The approach suggested by Josh is perfectly adequate for the
>> standard (non-dealiased) approach.
>> Paul
>> On Fri, 11 Nov 2011, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi,
>>> I'm sending this message again, because I got no answer for my last email.
>>> I have some questions regarding the additional term given in my previous
>>> message. I don't know where and in which subroutine I should add this term
>>> to the right hand side of the advection-diffusion equation. Also, could
>>> you please provide me with the best option I can take to dealias this term
>>> (if needed at all)? I wonder if you could help me in this regard.
>>> Best Regards,
>>> Alireza Karimi
>>>> Alireza,
>>>> For this, I'll assume that you have split V into V1, V2, V3, and that
>>>> they have the structure
>>>> V1(lx1,ly1,lz1,lelv)  (and likewise for the other two)
>>>> First, to multiply c*V1 (V2, V3), you can use col2.  It would look like
>>>> call col2(V1,c,n)
>>>> call col2(V2,c,n)
>>>> call col2(V3,c,n)
>>>> where n = nx1*ny1*nz1*nelv.  A couple of things to note here:
>>>> 1) col2 will overwrite V1 (V2, V3).  Effectively, the operation is
>>>> V1 = c*V1.  If this is not desirable, then you could use col3 with
>>>> something like
>>>>       call col3(cV1,V1,c,n)
>>>>   This will store it in cV1 and leave V1 untouched.
>>>> 2) You could run into aliasing issues by multiplying c and V
>>>> directly, and so it may be wise to dealias the product before taking
>>>> the derivative.  Developers, maybe you could suggest the best way of
>>>> going about doing this in Nek???
>>>> Moving on, to take the derivatives, there are a few choices.  One way
>>>> would be do to something like
>>>> call gradm1(dcV1dx,work1  ,work2  ,cV1)
>>>> call gradm1(work1  ,dcV2dy,work2  ,cV2)
>>>> call gradm1(work1  ,work2  ,dcV3dz,cV3)
>>>> call add4(divcV, dcV1dx, dcV2dy, dcV3dz, n)
>>>> which would give you div(cV) in the array divcV.  Note that dcV1dx,
>>>> dcV2dy, dcV3dz, work1, work2, and divcV all should have the same
>>>> storage structure as V1, c, etc.
>>>> This is probably the simplest way that I can think to do it, although
>>>> it is somewhat inefficient since we are computing, for instance,
>>>> d(cV1)/dy unnecessarily.  To make it more efficient, you can manually
>>>> compute the derivatives individually (take a look at the gradm1
>>>> subroutine to get an idea of how to do this, located in navier5.f in
>>>> the source)
>>>> Hope this helps, and developers, please correct me if I did something
>>>> horribly wrong  here :).
>>>> Josh
>>>> On Fri, Nov 4, 2011 at 4:59 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I want to solve an advection-diffusion equation in conjunction with the
>>>>> momentum and mass conservation equations. But my equation has an extra
>>>>> divergence term which I don't know how to calculate it in Nekton. So,
>>>>> denoting the scalar concentration field with c and velocity field with
>>>>> u,
>>>>> the equation turns out to be:
>>>>> dc/dt + u.grad c = Laplacian c - div (c V)
>>>>> which by d/dt I mean partial derivative with respect to time. V is a
>>>>> known
>>>>> vector field calculated from the vorticity tensor. I wonder if you could
>>>>> show me how to evaluate this additional term (the last term) in the user
>>>>> file.
>>>>> Best Regards,
>>>>> Alireza Karimi
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Josh Camp
>>>> "All that is necessary for the triumph of evil is that good men do
>>>> nothing" -- Edmund Burke
