[Nek5000-users] Calculation of Divergence Term
Sat Nov 12 11:21:36 CST 2011
Thanks a lot for your hints and I appreciate your help. Sorry for
interrupting when you were so busy.
Alireza Karimi
Quoting nek5000-users at lists.mcs.anl.gov:
> Dear Alireza,
> You would add this to qvol, since it is the convection-diffusion
> equation -- so, the routine is userq.
> You should precompute the term in userchk, store the result in
> a common block, and then dereference in userq.   Expanding on Josh's
> suggestion below you would have something like
> c-----------------------------------------------------------------------
>       subroutine userchk
>       common /mydiv/ divcv(lx1,ly1,lz1,lelt)
>       common /scrns/ dcv1dx(lx1,ly1,lz1,lelt)
>                    , dcv2dy(lx1,ly1,lz1,lelt)
>                    , dcv3dz(lx1,ly1,lz1,lelt)
>                    , work1 (lx1,ly1,lz1,lelt)
>                    , work2 (lx1,ly1,lz1,lelt)
>         then his calls... be sure to define n
>       return
>       end
>       subroutine userq  (ix,iy,iz,eg)
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
>       e = gllel(eg)
>       qvol = divcv(ix,iy,iz,e)  Be sure to check the sign of this term
>       return
>       end
> It's not a priori clear that you need to dealias this term.
> Dealiasing is needed in certain circumstance for stability -- it
> does not materially affect accuracy.  Without further context
> I cannot tell you whether you need to dealias or not.
> The approach suggested by Josh is perfectly adequate for the
> standard (non-dealiased) approach.
> Paul
> On Fri, 11 Nov 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I'm sending this message again, because I got no answer for my last
>> email. I have some questions regarding the additional term given in
>> my previous message. I don't know where and in which subroutine I
>> should add this term to the right hand side of the
>> advection-diffusion equation. Also, could you please provide me
>> with the best option I can take to dealias this term (if needed at
>> all)? I wonder if you could help me in this regard.
>> Best Regards,
>> Alireza Karimi
>>> Alireza,
>>> For this, I'll assume that you have split V into V1, V2, V3, and that
>>> they have the structure
>>> V1(lx1,ly1,lz1,lelv)  (and likewise for the other two)
>>> First, to multiply c*V1 (V2, V3), you can use col2.  It would look like
>>> call col2(V1,c,n)
>>> call col2(V2,c,n)
>>> call col2(V3,c,n)
>>> where n = nx1*ny1*nz1*nelv.  A couple of things to note here:
>>> 1) col2 will overwrite V1 (V2, V3).  Effectively, the operation is
>>> V1 = c*V1.  If this is not desirable, then you could use col3 with
>>> something like
>>>        call col3(cV1,V1,c,n)
>>>    This will store it in cV1 and leave V1 untouched.
>>> 2) You could run into aliasing issues by multiplying c and V
>>> directly, and so it may be wise to dealias the product before taking
>>> the derivative.  Developers, maybe you could suggest the best way of
>>> going about doing this in Nek???
>>> Moving on, to take the derivatives, there are a few choices.  One way
>>> would be do to something like
>>>  call gradm1(dcV1dx,work1  ,work2  ,cV1)
>>>  call gradm1(work1  ,dcV2dy,work2  ,cV2)
>>>  call gradm1(work1  ,work2  ,dcV3dz,cV3)
>>>  call add4(divcV, dcV1dx, dcV2dy, dcV3dz, n)
>>> which would give you div(cV) in the array divcV.  Note that dcV1dx,
>>> dcV2dy, dcV3dz, work1, work2, and divcV all should have the same
>>> storage structure as V1, c, etc.
>>> This is probably the simplest way that I can think to do it, although
>>> it is somewhat inefficient since we are computing, for instance,
>>> d(cV1)/dy unnecessarily.  To make it more efficient, you can manually
>>> compute the derivatives individually (take a look at the gradm1
>>> subroutine to get an idea of how to do this, located in navier5.f in
>>> the source)
>>> Hope this helps, and developers, please correct me if I did something
>>> horribly wrong  here :).
>>> Josh
>>> On Fri, Nov 4, 2011 at 4:59 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Hi,
>>>> I want to solve an advection-diffusion equation in conjunction with the
>>>> momentum and mass conservation equations. But my equation has an extra
>>>> divergence term which I don't know how to calculate it in Nekton. So,
>>>> denoting the scalar concentration field with c and velocity field with u,
>>>> the equation turns out to be:
>>>> dc/dt + u.grad c = Laplacian c - div (c V)
>>>> which by d/dt I mean partial derivative with respect to time. V is a known
>>>> vector field calculated from the vorticity tensor. I wonder if you could
>>>> show me how to evaluate this additional term (the last term) in the user
>>>> file.
>>>> Best Regards,
>>>> Alireza Karimi
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> Josh Camp
>>> "All that is necessary for the triumph of evil is that good men do
>>> nothing" -- Edmund Burke
