[Nek5000-users] Meshing complex geometries
Mon Nov 7 08:34:44 CST 2011
Dear Outi,
I would use prenek.  It is actually quite good for 2D geometries.
If you contact me off-list I can assist further.
Paul
On Mon, 7 Nov 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I have been using Nek5000 previously to compute global stability of flows in
> relatively simple, plane 2D geometries.
> Now I am considering the possibility to use Nek5000 for a rather complicated
> 2D axisymmetric geometry.
> The flow is an axisymmetric jet with small co-flow outside. What is
> complicated is that I want to include the nozzle prior to the actual jet
> outlet. The nozzle should be converging, and contain an inner flow stream
> (jet flow) and an outer flow stream (co-flow), separated by a solid wall. We
> have an experiment in a similar geometry.
> I thought that a good way to find out whether this works in Nek5000 or not is
> to try it.
> So, my question is very basic:
> What would be a good way to to proceed, when meshing a complicated
> axisymmetric geometry like this?
> Many thanks!
> Outi Tammisola
> Nek5000-users mailing list
