[Nek5000-users] Meshing complex geometries
Mon Nov 7 04:11:27 CST 2011
Dear Neks,
I have been using Nek5000 previously to compute global stability of
flows in relatively simple, plane 2D geometries.
Now I am considering the possibility to use Nek5000 for a rather
complicated 2D axisymmetric geometry.
The flow is an axisymmetric jet with small co-flow outside. What is
complicated is that I want to include the nozzle prior to the actual
jet outlet. The nozzle should be converging, and contain an inner flow
stream (jet flow) and an outer flow stream (co-flow), separated by a
solid wall. We have an experiment in a similar geometry.
I thought that a good way to find out whether this works in Nek5000 or
not is to try it.
So, my question is very basic:
What would be a good way to to proceed, when meshing a complicated
axisymmetric geometry like this?
Many thanks!
Outi Tammisola
