[Nek5000-users] Compilation error
Tue May 24 09:13:40 CDT 2011
Hi Nek's,
Up to now I have compiled and run the code on the various workstations
available in my lab. I am now trying to compile it (only in serial for the
moment) on an IBM Power 6 (
http://www.idris.fr/su/Scalaire/vargas/hw-vargas.html) but I encounter an
error (which is the reason why I do not compile it using mpi support
yet). Following is the outpost from the compilation:
xlf_r -qsuppress=cmpmsg -o nek5000  obj/stenosis.o obj/drive.o obj/drive1.o
obj/drive2.o obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o obj/hsmg.o
obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o obj/navier6.o
obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o obj/byte.o
obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/cvode_driver.o
obj/nek_comm.o obj/init_plugin.o obj/setprop.o obj/qthermal.o
obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o obj/dsygv.o
obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o obj/singlmesh.o
obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o obj/jl2_sarray_sort.o
obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
ld: 0711-317 ERROR: Undefined symbol: .etime
ld: 0711-345 Use the -bloadmap or -bnoquiet option to obtain more
information.
gmake: *** [nek5000] Error 8
Attached is the whole compiler.out file also. Does anyone have an idea?
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110524/4e80e954/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110524/4e80e954/attachment.obj>
