[Nek5000-users] Average in arbitrary direction
Thu May 19 15:06:05 CDT 2011
Hi Josh,
yes, there are 3 intpts* routines from postpro.f that you can use. I have an example but I need to update it for the current repo version of this routines -- I'll send it to you once I modify and test it.
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, May 19, 2011 9:21:03 AM
Subject: Re: [Nek5000-users] Average in arbitrary direction
Hello Paul,
This sound like exactly what I need.  I didn't find anything like
interp() while using grep in the repo--are you referring to the
routines found in postpro.f ??
Josh
On Wed, May 18, 2011 at 3:59 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Josh,
> You can use the interp() routines --- let me check if we have
> examples in the repo.
> These are somewhat expensive, so if you're also integrating in
> time (even over just 10 steps), it would pay to only interpolate
> the time-averaged data, rather than interpolating every timestep
> and then averaging the profiles.   However, I can understand that
> there are times you'd want the full time signal.
> The best integration formulae for periodic signals (e.g., in your theta
> direction and perhaps in z, if you have periodicity)
> is to simply sum the values, sampled uniformly in space (z or
> theta), and dived by n, the number of samples.   You do need
> to sample with sufficient density to capture all the wiggles ---
> another reason that time averaging has value.
> Paul
> On Wed, 18 May 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello Neks,
>> I have looked at the turbChannel example for an example on planar
>> averaging.
>> However, I was wondering if there was any advice  on how to do this if
>> the elements aren't exactly "nice"... (i.e., the elements may have
>> arbitrary rotations)
>> Specifically, I have a pipe flow, and I am wanting to do an average in
>> the z (axial) direction.  My initial thoughts were to interpolate my
>> values to set R, theta components, and then average this along z.  I'm
>> stuck on the best way to do either one of these operations, however
>> (especially because I would like to use an integration rule to compute
>> the average in the z direction).
>> If anyone could point me in the right direction, that would be a big
>> help.  Thanks!
>> Josh Camp
>> "All that is necessary for the triumph of evil is that good men do
>> nothing" -- Edmund Burke
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Josh Camp
