[Nek5000-users] hpts issue: not dumping anything
Sun Mar 27 17:06:26 CDT 2011
Hi Michael,
You would need to close it only after your
run is done?  Otherwise, it closes and (I guess)
reopens after each call and then you for sure
wouldn't get anything.
It's hard for me to check w/o being on precisely
the same platform.
Unfortunately I'm on travel right now - otherwise
we could perhaps sort it out through skype.
Paul
On Sun, 27 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Do you mean add to the hpts routine within postpro.f an explicit close( ) command after writing to hpts.out?  I see what you mean
> that nothing actually shows up unless the run is closed, in which case all of my data now appears.
> - Michael
> From: nek5000-users at lists.mcs.anl.gov
> To: "Nekton User List" <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday, March 15, 2011 1:54:08 AM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] hpts issue: not dumping anything
> Hi Michael, I've had some experiences on IBM machines in the past where the file never appeared unless it was explicitly closed. Surprisingly, this was the case even if I properly exitted. I've not looked at the hpts source, but this may be the issue. Can you try closing the file prior to exitting? Obviously this is a pain in a situation where you want to let your run keep going until terminated by the end of your allocated block, but I wouldn't know anyway around it. There may be a compiler option to force it to not buffer the I/O so parsimoniously. Paul On Mon, 14 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote: > > > Hi, > > > > I am having an issue with hpts.  The issue is on a machine with the operating system AIX 5.3.  The compilers > > are mpxlf for Fortran, and mpcc for  the C compiler. The history point routine works on all other machines I > > have used, except for this one. > > > > The simulation runs fine, saying that it is dumping history points to hpts.ou
 t in the output log.  However, nothing is ever actually written > > to hpts.out, not even the header. > > > > I am not sure what the issue is. I suspect something with the compilers or operating system as this is the only difference > > between this case, and all other cases.   Any thoughts? > > > > - Michael M.
> _______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
