[Nek5000-users] hpts issue: not dumping anything
Tue Mar 15 01:54:08 CDT 2011
Hi Michael,
I've had some experiences on IBM machines in the past where the
file never appeared unless it was explicitly closed.
Surprisingly, this was the case even if I properly exitted.
I've not looked at the hpts source, but this may be the issue.
Can you try closing the file prior to exitting?
Obviously this is a pain in a situation where you want to
let your run keep going until terminated by the end of
your allocated block, but I wouldn't know anyway around it.
There may be a compiler option to force it to not buffer
the I/O so parsimoniously.
Paul
On Mon, 14 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I am having an issue with hpts.  The issue is on a machine with the operating system AIX 5.3.  The compilers
> are mpxlf for Fortran, and mpcc for  the C compiler. The history point routine works on all other machines I
> have used, except for this one.
> The simulation runs fine, saying that it is dumping history points to hpts.out in the output log.  However, nothing is ever actually written
> to hpts.out, not even the header.
> I am not sure what the issue is. I suspect something with the compilers or operating system as this is the only difference
> between this case, and all other cases.   Any thoughts?
> - Michael M.
