[Nek5000-users] Prandtl number in the heat transport equation
Wed Mar 9 11:33:06 CST 2011
Hi Alex,
This would be common usage? -- Paul
    1.00000     P001: DENSITY
   -10000.      P002: VISCOS      <-- Re=10,000
   0.000000E+00 P003: BETAG
   0.000000E+00 P004: GTHETA
   0.000000E+00 P005: PGRADX
   0.000000E+00 P006:
    1.00000     P007: RHOCP
   -1000        P008: CONDUCT    <-- Pe = 1,000
On Wed, 9 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> p8=1 or p8=-Pe?
> Maybe you meant p7=-Pe?.
> Thanks
> On Wed, 2011-03-09 at 10:42 -0600, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Hi Alex,
>> I typically set p1 and p8 to unity, then set p2 = -Re and p8= -Pe,
>> where Pe is the Peclet number and Pr is then Pe/Re.
>> Paul
>>> Hi,
>>> How can I set the Pr number in the fully-developed channel flow with
>>> scalar transport (constant but different scalar values at the walls)?.
>>> This parameter is part of the coefficient of the diffusive term in the
>>> heat transport equation (1/Re/Pr).
>>> Should I use parameters 7 (RHOCP) and 8 (CONDUCT) in the rea file?.
>>> Thanks.
>>> Alexandre Fabregat, PhD.
>>> Mail: afabrega at uottawa.ca
>>> Phone: 630 562-5800 (ext. 6293)
>>> Office: B207
>>> Mechanical Engineering Department
>>> University of Ottawa
>>> 161 Louis Pasteur, K1N6N5, Ottawa ON
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Office: B207
