[Nek5000-users] Prandtl number in the heat transport equation
Wed Mar 9 11:16:31 CST 2011
Hi Paul,
p8=1 or p8=-Pe?
Maybe you meant p7=-Pe?.
Thanks
On Wed, 2011-03-09 at 10:42 -0600, nek5000-users at lists.mcs.anl.gov
wrote:
> Hi Alex,
> I typically set p1 and p8 to unity, then set p2 = -Re and p8= -Pe,
> where Pe is the Peclet number and Pr is then Pe/Re.
> Paul
> On Wed, 9 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> > Hi,
> > How can I set the Pr number in the fully-developed channel flow with
> > scalar transport (constant but different scalar values at the walls)?.
> > This parameter is part of the coefficient of the diffusive term in the
> > heat transport equation (1/Re/Pr).
> > Should I use parameters 7 (RHOCP) and 8 (CONDUCT) in the rea file?.
> > Thanks.
> > Alexandre Fabregat, PhD.
> > Mail: afabrega at uottawa.ca
> > Phone: 630 562-5800 (ext. 6293)
> > Office: B207
> > Mechanical Engineering Department
> > University of Ottawa
> > 161 Louis Pasteur, K1N6N5, Ottawa ON
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Office: B207
