[Nek5000-users] Calculating local skin friction coefficient
Wed Mar 2 13:32:54 CST 2011
Hi Harish,
I have not used comp_sij routine myself but from what I see in the source
(navier5.f:2266)
          sij(i,4,e) = j*  ! du/dy + dv/dx
which is different from your goal of du/dy unless v is not a function of
x.
I am assuming you set your j1,j2 correctly for your boundary element
surfaces and you solve for non-dimentional values.  If you have constant
properties then you do not need to fill up the array visc -- you can just
use param(2) instead.
It may be a good idea as usual to set a test problem with analytical
non-trivial initial conditions and run it w/ nsteps=0 just to make sure
you get the answer you want...
Best,
Aleks
On Wed, 2 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> I am trying to compute local skin friction coefficient (C_f) at bottom
> wall in a backward facing step. The flow is simulated at Re=5000. I need
> to figure this out to test the effect of time step size (dt) on transition
> to turbulence.
> Quantities used:
> tau_w = wall shear stress
> U_inf = reference velocity
> definition of C_f := 2 * tau_w/ rho*U_inf
> tau_w = -mu*du/dy ( at wall)
> C_f = 2 * nu * du/dy
> To compute C_f I am using use the following (code snippet):
> call comp_sij(sij,nij,vx,vy,vz,ur,us,ut,vr,vs,vt,wr,ws,wt)
>         v  = visc(j1,j2,1,e)        ! from subroutine drgtrq()
>        s12 = sij(j1,j2,1,4,e)
>        s22 = sij(j1,j2,1,2,e)
>        s32 = sij(j1,j2,1,5,e)
>        Cf  = 2*v*s12
> Am I doing this right? Any help would be appreciated.
> Thanks,
> Harish.
> Nek5000-users mailing list
