[Nek5000-users] hpts and pressure
Tue Jun 14 14:34:31 CDT 2011
Yes - that would be a good place!
On Tue, 14 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Why not after the pressure solve every time step? I don't think it
> will add much.
> -Stefan
> On 6/14/11, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov> wrote:
>> Josh, Stefan,
>> Correct... we should just add the map to the hpts
>> routine.   Maybe Katie can take care of this.
>> Thanks for raising this issue!
>> Paul
>>> Hi
>>> You are right, the pressure is not mapped automatically. This issue
>>> was already discussed in
>>> https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2010-May/000584.html.
>>> At the moment there is only a trigger to map the pressure in case we
>>> are dumping a field file
>>> @Paul: I am not sure where we should trigger the pressure mapping but
>>> the way it's implement now is error prone.
>>> -Stefan
>>>> Hello,
>>>> It appears my hypothesis was correct.  I post the following for
>>>> reference to any users who run into the same issue in the future (and
>>>> I apologize in advance if this question has already been answered
>>>> before, I didn't see anything in my search, but that doesn't mean it
>>>> wasn't there).
>>>> 1)  I included the following in the variable declarations of userchk()
>>>>       common /scrcg/ pm1(lx1,ly1,lz1,lelv)  ! Mapped pressure
>>>>       real pa(lx1,ly2,lz2), pb(lx1,ly1,lz2) ! Working arrays for mappr
>>>> 2) Then, before I call hpts, I call mappr
>>>>       if (mod(istep,10).eq.0) then   ! Only call this every 10th step
>>>>          call mappr(pm1,pr,pa,pb)   ! Map pressure first
>>>>          call hpts
>>>>       endif
>>>> For my case, I didn't want to call hpts every time step to prevent
>>>> hpts.out from becoming too large.
>>>> I haven't run this for too long, but on a preliminary basis the
>>>> results look good.  It seems that the scrcg common block must be
>>>> included in userchk for this to work, as pm1 isn't a part of any of
>>>> the standard "include" files.
>>>> Developers and other users, feel free to chime in if there is a more
>>>> efficient or elegant solution to this problem.
>>>> Thanks,
>>>> Josh
>>>> On Mon, Jun 13, 2011 at 6:42 PM,  <nek5000-users at lists.mcs.anl.gov>
>>>> wrote:
>>>>> Hi Josh,
>>>>> Yes, it seems to me that either htps() needs modification for Pn-Pn-2
>>>>> pressure points or pr() should be mapped to pm1() before calling htps()
>>>>> as
>>>>> you suggested -- something along the lines for .not.ifsplit in
>>>>> prepot.f:219
>>>>>         if (ifsplit) then
>>>>>            call copy(pm1,pr,ntot1)
>>>>>         else
>>>>>            do 1000 e=1,nelv
>>>>>               call mxm (ixm21,nx1,pr(1,1,1,e),nx2,pa(1,1,1),nyz2)
>>>>>               do 100 iz=1,nz2
>>>>>                  call mxm (pa(1,1,iz),nx1,iytm21,ny2,pb(1,1,iz),ny1)
>>>>>  100          continue
>>>>>               call mxm (pb(1,1,1),nxy1,iztm21,nz2,pm1(1,1,1,e),nz1)
>>>>>  1000       continue
>>>>>         endif
>>>>> Best,
>>>>> Aleks
>>>>> ----- Original Message -----
>>>>> From: nek5000-users at lists.mcs.anl.gov
>>>>> To: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
>>>>> Sent: Monday, June 13, 2011 5:29:50 PM
>>>>> Subject: [Nek5000-users] hpts and pressure
>>>>> Hello Neks,
>>>>> I am trying to output pressure data at various points using the hpts
>>>>> routine.
>>>>> The values that are output for the first time step look ok, but all
>>>>> subsequent time steps seem to give garbage (i.e. the pressures given
>>>>> in hpts.out are way different that what is given by visualizing
>>>>> pressure in VisIt).  I know previously that this was an issue for
>>>>> someone and it was thought that passive scalars may be messing the
>>>>> hpts output up, but in my case I don't output temperature or pressure.
>>>>> I looked at the hpts routine and noticed that it uses pm1 when it is
>>>>> stacking the field variables into the working array.  Since I am using
>>>>> a Pn-Pn-2 formulation for my case, do I need to use the mappr
>>>>> subroutine in my usrchk to map the pressure from mesh 2 to mesh 1
>>>>> before calling hpts()?
>>>>> I'm assuming the issue arises because I am calling hpts more
>>>>> frequently than I am outputing field files, and thus perhaps pm1 isn't
>>>>> properly being updated (or perhaps it may have already been
>>>>> destroyed).
>>>>> Thanks,
>>>>> Josh Camp
>>>>> "All that is necessary for the triumph of evil is that good men do
>>>>> nothing" -- Edmund Burke
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Josh Camp
