[Nek5000-users] Error in generalev
Thu Jun 2 14:29:51 CDT 2011
Hi Josh,
Can you send me your files for this case.  (.map, .rea, .usr, and SIZE).  I
think you are probably right about the geometry being the issue, possibly
the boundary conditions.  I will take a look at it and see if anything
sticks out or if we can reproduce the problem locally.
Also, how did you create the mesh for this case?
Katie
On Thu, Jun 2, 2011 at 1:16 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello Aleks,
> I compiled with the option for trapping a floating point exception,
> and it gives the message that it trapped the exception in the same
> spot as before (which is very odd).
> It might be worth mentioning that if I run in post-processing mode
> (nsteps=0), it still traps an exception while in userchk (although I
> don't think it's anything specific in my userchk, as I've used the
> same .usr file before).  The floating point exception occurs when I
> make a call to col3 with vx and vx (to get the velocity squared), but
> when I calculate the max and min velocities earlier in userchk, I
> don't have any issues.
> My guess is that something with my geometry is wrong, but it passes
> the various geometry checks I see in the logfile.  I'm not sure what
> is causing the failure at this point--any thoughts?
> Josh
> On Wed, Jun 1, 2011 at 6:38 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> > Hi Josh,
> > Have you tried to compile with trapping floating point exception?
> > E.g., the compiler flag for pgf77 is
> > -Ktrap=fp
> > Then you may get a better idea where Inf & Nan first appear...
> > Best,
> > Aleks
> > On Wed, 1 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> >> Hello Neks,
> >> I've recently come across an error I haven't seen before.    It occurs
> >> in the routine "generalev" at the beginning of my run.
> >> It looks like the matrix "a" and "b" being fed to the routine have an
> >> Infinity or NaN at position (0,0).  Are there any ideas of what could
> >> cause this type of error?
> >> I have attached the logfile to this email.
> >> Thanks,
> >> Josh Camp
> >> "All that is necessary for the triumph of evil is that good men do
> >> nothing" -- Edmund Burke
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Josh Camp
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110602/55131115/attachment.html>
