[Nek5000-users] Postx
Fri Jan 21 12:00:46 CST 2011
Hi Himanshu,
Make sure that your parameter(23)=3 in .rea which is your number of passive scalars or NPSCAL.  If this does not help, can you tar up your .fld & .rea file and email me it offline (obabko at mcs.anl.gov) or send me the link to it on the web?
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, January 20, 2011 3:14:50 PM
Subject: Re: [Nek5000-users] Postx
Hi Aleks,
I made the changes you suggested and re-compiled postx. But, the passive scalar option still does not show up when I do "set plot format". Please let me know if i missed anything or I need to do something differently?
Thank you,
Himanshu
On Fri, Jan 14, 2011 at 8:19 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hi Himanshu,
Sorry, I forgot the name of the file:
nek5_svn/trunk/tools/postnek/basics.inc
Best,
Aleks
Sent: Thursday, January 13, 2011 2:59:27 PM
Hi Aleks,
Thank you for the suggestion. In the postnek directory there are many .f files, do you know which one has the MAXFLD parameter?
Himanshu
On Thu, Jan 13, 2011 at 3:37 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hi Himanshu,
Try to increase MAXFLD parameter in nek5_svn/trunk/tools/postnek (i.e., maximum total number of fields in .fld file) and recompile clean.
Best,
Aleks
On Thu, 13 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
Hello neks,
I am trying to use postx to read some fld files that have passive scalar
information. There are 3 passive scalars. The passive scalar options appear
when I do "Set Quantity". But, when I try to set the plot format and read
the input file, the passive scalar option is not shown in the Nekton menu.
The velocity, co-ordinates, temperature options are present. Any idea why
the passive scalar option does not appear?
Thank you,
Himanshu
On Tue, Jan 11, 2011 at 11:07 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hello Neks,
I am trying to post process the fld files using postx to generate a uniform
xy grid of passive scalar data. During post processing the top half of the
circular cross-section is cut-off (its a cylindrical domain with aspect
ratio of 10 i.e radius to depth). The output file generated has only zeros
in it. I have checked the input file and it has information of the entire
domain. Any idea if i need to do something differently.
Himanshu
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
