[Nek5000-users] Help with planar averaging for dyn smag
Fri Feb 18 21:07:55 CST 2011
Hi Harish,
I've added a function that will homogenize any function on mesh
one (lx1,ly1,lz1) in the z direction, assuming you know how many
elements you have in the x-y plane, as would be the case if your
mesh is generated using n2to3, say.
To use it, you must set lelx and lely in SIZE such that the
product lelx*lely >= nelxy.   And you similarly need to define
nelx and nely values.  Here are some sample lines from my userchk
routine:
       call outpost(vx,vy,vz,pr,t,'   ')    ! Output the orginal field
       nelx = 8                             ! Pick an nelx,nely pair
       nely = 8                             ! such that nelx*nely matches my domain
       call z_distribute(vx)                ! Homogenize vx in the z-direction
       call z_distribute(vy)                ! Homogenize vy in the z-direction
       call z_distribute(vz)                ! Homogenize vz in the z-direction
       call z_distribute(pr)                ! Homogenize pr (only for Pn-Pn!!)
       call outpost(vx,vy,vz,pr,t,'   ')    ! output homogenized field and quit
       call exitti('quit after z-distribute$',nelx)
I've committed "z_distribute" to the svn repo.
Paul
On Mon, 14 Feb 2011, Harish Kanchi wrote:
> Hello Paul,
> I have been working on setting up a case for dyn smag. It is the same case
> that ran with Pn/Pn and smaller dt.
> It has NEL = 656, made up for 4 blocks. I build the 3D mesh with genbox.
> Here is the genbox file used to produce the mesh.
> In my case the homogeneous direction is the z-direction. Here is the
> subroutine I am using for planar averaging. But it does not work!!
> Any help would be appreciated.
> Thanks,
> Harish.
> bfs3d.rea
> -3                         spatial dimension (if negative dump .re2 file)
> 1                         number of fields
> box_1
> -18 -2 -4                nelx,nely,nelz (negative --> auto spacing)
> 0.0  20.0 1.085          x_0  x_1 ratio
> -1.0 -0.5 2.6
> 0.0  4.0  1
> W  ,O  ,W  ,E  ,P  ,P    bc's  ! west,east,south,north,bottom,top
> box_2
> -0.5  0.0  0.39
> 0.0  4.0  1
> W  ,O  ,E  ,E  ,P  ,P    bc's  ! west,east,south,north,bottom,top
> box_3
> -18 -4 -4                nelx,nely,nelz (negative --> auto spacing)
> 0.0  5.0  2.8
> 0.0  4.0  1
> E  ,O  ,E  ,SYM,P  ,P    bc's  ! west,east,south,north,bottom,top
> box_4
> -5 -4 -4                 nelx,nely,nelz (negative --> auto spacing)
> -10.0 0.0 0.58           x_0  x_1 ratio
> 0.0  5.0  2.8
> 0.0  4.0  1
> v  ,E  ,W  ,SYM,P  ,P    bc's  ! west,east,south,north,bottom,top
> c-----------------------------------------------------------------------
>      subroutine planar_average_t(ua,u,w1,w2)
> c
> c     Compute r-s planar average of quantity u()
> c
>      include 'SIZE'
>      include 'GEOM'
>      include 'PARALLEL'
>      include 'WZ'
>      include 'ZPER'
>      real ua(nz1,nelz),u(nx1,ny1,nx1,nelv),w1(nz1,nelz),w2(nz1,nelz)
>      integer e,eg,ex,ey,ez
>      nz = nz1*nelz
>      call rzero(ua,nz)
>      call rzero(w1,nz)
>      blk1 = 144 ! 18*2*4
>      blk2 = 288 ! 18*2*4
>      blk3 = 576 ! 18*4*4
>      blk4 = 656 ! 18*4*4
>      do e=1,nelt
>         eg = lglel(e)
>         if(eg .le. blk1) then
>            nelx = 18
>            nely = 2
>            nelz = 4
>            call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
>         elseif(eg .gt. blk1 .and. eg .le. blk2) then
>            nelx = 18
>            nely = 2
>            nelz = 4
>         elseif(eg .gt. blk2 .and. eg .le. blk3) then
>            nelx = 18
>            nely = 4
>            nelz = 4
>         elseif(eg .gt. blk3 .and. eg .le. blk4) then
>            nelx = 5
>            nely = 4
>            nelz = 4
>         endif
>         do k=1,nz1
>         do j=1,ny1
>         do i=1,nx1
>            zz = (1.-zgm1(k,3))/2.  ! = 1 for i=1, = 0 for k=nx1
>            aa = zz*area(i,1,5,e) + (1-zz)*area(i,1,6,e)  ! wgtd jacobian
>            w1(k,ez) = w1(k,ez) + aa
>            ua(k,ez) = ua(k,ez) + aa*u(i,j,k,e)
>         enddo
>         enddo
>         enddo
>      enddo
>      call gop(ua,w2,'+  ',nz)
>      do i=1,nz
>         ua(i,1) = u(a,i)/w1(i,1) ! Normalize
>      enddo
>      return
>      end
>      subroutine planar_fill_t(u,ua)
> c
> c     Fill array u with planar values from ua().
> c     For tensor-product array of spectral elements
> c
>      include 'SIZE'
>      include 'GEOM'
>      include 'PARALLEL'
>      include 'WZ'
>      include 'ZPER'
>      real u(nx1,ny1,nz1,nelv),ua(lz1,lelz)
>      blk1 = 144 ! 18*2*4
>      blk2 = 288 ! 18*2*4
>      blk3 = 576 ! 18*4*4
>      blk4 = 656 ! 18*4*4
>      do e=1,nelt
>         eg = lglel(e)
>            nelx = 18
>            nely = 2
>            nelz = 4
>            nelx = 18
>            nely = 2
>            nelz = 4
>            nelx = 18
>            nely = 4
>            nelz = 4
>            nelx = 5
>            nely = 4
>            nelz = 4
>         endif
>         do k=1,nz1
>         do j=1,ny1
>         do i=1,nx1
>            u(i,j,k,e) = ua(k,ez)
>         enddo
>         enddo
>         enddo
>      enddo
>      return
>      end
