[Nek5000-users] stokes flow with time-dependent boundary
Mon Dec 19 10:46:00 CST 2011
Hello, guys,
i am a new guy to Nek5000, i saw the manual of nek5000 that it can solve
the steady stokes flow.
i guess when i solve such a flow, do i need to set it as a transient
simulation with time-derivative term included to get  a steady-state
solution? or, i can solve it by a direct solver method to get the
solution immediately?
since i want to add some time-dependent boundary condition for the
steady stokes flow, so it will be pretty nice if i can solve it using
the direct solver, for each time step, i solve one stokes flow; if
nek5000 cannot solve it in such a way, i guess i have to use the first
way; then for each time step i have to solve a transient problem to
approach the steady state with some artificial time step used.
i am not sure if i have stated my problem clearly. hopefully you guys
have some experience on the feasibility of the two ways mentioned above.
Thank you in advance.
lailai
