[Nek5000-users] Solving for fluid flows on a sphere
Sun Aug 14 07:56:47 CDT 2011
Hi Paul,
Thanks for the diagnosing this problem. Indeed it is bad initial data. At
the moment I do not have specific initial data or forcing to work with and
so I'm just trying out the feasibility of using NEK to solve on the shell. I
should have some concrete initial data in the next couple of days.
When I try to repeat the run with
ux = 0.0
uy = 0.0
uz = 0.0
and
ffx = 0.0
ffy = 0.0
ffz = 1.0
NEK shows a lot of convergence errors. Could you check this out?
I've attached the .rea file.
Mani
On Sun, Aug 14, 2011 at 5:31 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mani,
> I ran this with
> G="-g -Ktrap=fp"
> and the "nekd" script in serial (just gdb nek5000 after
> setting up requisite files).
> Here is the output:
> Program received signal SIGFPE, Arithmetic exception.
> 0x000000000040376c in useric_ (ix=1, iy=1, iz=1, ieg=3)
>    at /homes/fischer/nek_debug/mani/**z.f:83
> 83            utheta = 1.0/(x**2 + y**2)**0.5
> (gdb)
> This makes sense -- you have a pole singularity in
> this formulation.  I'm certain it's a removable singularity if you just
> rework your ux/uy velocity
> definition.
> Please let me know if this resolves the issue.
> Paul
> On Sun, 14 Aug 2011, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Hi Paul,
>> I setup a simulation but I keep getting NaN's when I give nontrivial
>> initial data. I'm attaching the relevant files. Could you please try it out?
>> I checked that the initial data is divergence free and satisfies the
>> boundary conditions (u_r = 0, du_theta/dr = 0, du_phi/dr = 0).
>> Regards,
>> Mani
>> On 08/11/2011 05:46 PM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>> Hi Mani,
>>> Probably your best bet is to use a very thin layer of elements
>>> in a 3D spherical shell with SYM bcs on faces 5 & 6, plus the
>>> stress formulation.  I would imagine that a shell of thickness
>>> .001 with R=1.0 might be feasible.
>>> Instructions for constructing a 3D shell can be found in
>>> www.mcs.anl.gov/~fischer/**primer.pdf<http://www.mcs.anl.gov/~fischer/primer.pdf>
>>> (Some of this info may already have been transferred into
>>> current manual.)   We can help with this if you need any
>>> assistance.
>>> Regards,
>>> Paul
>>> On Thu, 11 Aug 2011, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>>  Hi Nek devs,
>>>> Is it possible to use NEK to solve for Navier Stokes equations on the
>>>> surface of a sphere, where r is fixed and the velocity varies in theta
>>>> and
>>>> phi?
>>>> Thanks,
>>>> Mani Chandra
>>>> ______________________________**_________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/77fb6347/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110814/77fb6347/attachment.obj>
