[Nek5000-users] userf/userq in .usr file
Fri Aug 12 08:18:21 CDT 2011
Thank you for the clarification Aleks.  I wanted to make sure I wasn't
unknowingly integrating my forcing function twice :).
Josh
On Thu, Aug 11, 2011 at 5:07 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Josh,
> Yes, you are right that the variable SOURCE in userq seems to be outdated -- only qvol is used in nekuq().
> As far as multiplication of ffx,... by masss matrix is concerned -- it's done in makeuf() (after calling nekuf() which calls userf()), so there is no need to do the multiplication in userf():
>      subroutine makeuf
>      CALL NEKUF   (BFX,BFY,BFZ)
>      CALL OPCOLV (BFX,BFY,BFZ,BM1)
> Best,
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday, August 9, 2011 4:43:15 PM
> Subject: [Nek5000-users] userf/userq in .usr file
> Hello Neks,
> I had a couple of questions regarding userf and userq.
> 1)  If we add something to, for example, ffx in userf, is that
> "something" subsequently multiplied by the mass matrix later on in the
> source code, or is that on the user to multiply ffx(i,j,k,e) by its
> appropriate bm1 entry?
> 2)  In userq, is "source" used for anything?  I tried looking through
> the source code, and I can see where "qvol" is used, but not where
> "source" is used.
> Thanks,
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do
> nothing" -- Edmund Burke
> Nek5000-users mailing list
Josh Camp
