[Nek5000-users] Error stemming from genbox
Thu Aug 11 15:56:19 CDT 2011
HI Josh,
Yes, the current version of genbox should be set up to set the logical flags
a little differently than before.
Now, the user is able to create a .rea file for heat only simulations by
setting the number of fields (line 3 in the .box file) to negative, so part
of the logical flags are written out differently than before.
However, it shouldn't overwrite the IFTRAN logical, that is an error.  I
will take care of it and update the repo.
Thanks!!
Katie
On Thu, Aug 11, 2011 at 3:15 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Neks,
> I was getting an odd error in Nek when using geometry generated from
> the newest version of genbox (repo 718) that I did not get from repo
> 713 (the log file from the run using genbox from repo 718 is
> attached--the error message appears at the top).
> After comparing the two generated .rea files, I found the issue.  On
> older versions of genbox, it seems that it took the base.rea file
> specified and used the upper portion of it to generate the header of
> your new .rea file.  But, on the new version, it doesn't appear to do
> this for the logical flags.  So, the issue I was running into (while
> running the example turbChannel) was that
> IFTRAN    T
> in base.rea was being replaced by
> IFHEAT    F
> in the generated box.rea file, where in the older version it kept them
> the same.   Manually changing IFHEAT    F   back to IFTRAN    T
> removed the error message and the case ran fine as normal.
> I'm not sure if this was an intentional change or not, or if anyone
> else has run into this issue, but I thought this might help clear up
> any confusion if anyone else runs into this same problem (took me a
> while to figure out what exactly was going wrong :) ).
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do
> nothing" -- Edmund Burke
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110811/4bd43ea8/attachment.html>
