[Nek5000-users] Scalar Derivatives / Scalar Dissipation
Fri Apr 15 12:21:45 CDT 2011
Ups, I missed to post the magsqr subroutine:
     subroutine magSqr(a,b1,b2,b3,n)
      include 'SIZE'
      real a(1)
      real b1(1),b2(1),b3(1)
      if(if3d) then
        do i=1,n
           a(i) = b1(i)*b1(i) + b2(i)*b2(i) + b3(i)*b3(i)
        enddo
      else
        do i=1,n
        enddo
      end
      return
      end
On 4/15/11, S K <stgeke at googlemail.com> wrote:
> Hi Alex,
> Here a routine I coded up some time ago to compute the scalar dissipation
> rate.
> Hth,
> Stefan
> c-----------------------------------------------------------------------
>       subroutine scalDisp(chi,Z,D)
> c
> c    compute scalar dissipation rate
> c    chi := D * |grad Z|^2
> c
>       include 'SIZE'
>       include 'TOTAL'
>       real chi(lx1,ly1,lz1,1)
>       real Z  (lx1,ly1,lz1,1)
>       real D  (lx1,ly1,lz1,1)
>       common /scrns/ w1(lx1,ly1,lz1,lelt)
>      $              ,w2(lx1,ly1,lz1,lelt)
>      $              ,w3(lx1,ly1,lz1,lelt)
>       ntot = nx1*ny1*nz1*nelv
>       call opgrad (w1,w2,w3,Z)
>       call opdssum(w1,w2,w3)
>       call opcolv (w1,w2,w3,binvm1)
>       call magsqr (chi,w1,w2,w3,ntot)
>       call col2   (chi,D,ntot)
>       return
>       end
> On 4/15/11, nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Alex,
>> I'm assuming your call is in userchk?
>> There are several items of which you should be aware (mostly related
>> to parallel processing, since the code fragment is typically
>> being executed on multiple processors).
>> First - you should use t(....,2) as the argument to gradm1, if
>> you want dissipation of PS1.  (I'm assuming that you're also
>> tracking temperature -- otherwise you can store your passive
>> scalar in the temperature array.  The data layout is as follows:
>>          variable       pointer
>>        temperature:    t(1,1,1,1,1)
>>        pass. scal 1:   t(1,1,1,1,2)
>>        pass. scal 2:   t(1,1,1,1,3)
>>            etc.
>> You should make certain that ldimt in SIZE is large enough
>> to support the desired number of passive scalars.
>> Assuming you want to compute dissipation rate for passive
>> scalar 1, I would modify your code to read:
>>        call gradm1(dc1dx, dc1dy, dc1dz, t(1,1,1,1,2) )
>>        n = nx1*ny1*nz1*nelv
>>        scalar_diss = ( glsc3(dc1dx,bm1,dc1dx,n)
>>       $              + glsc3(dc1dy,bm1,dc1dy,n)
>>       $              + glsc3(dc1dz,bm1,dc1dz,n) ) /volvm1
>>        if (nid.eq.0) write(6,1) istep,time,scalar_diss
>>      1 format(i9,1p2e14.6,' scalar diss')
>> OK --- What does this do?
>> The first part is as you had it, save that you take the
>> gradient of t(....,2), which is where PS1 resides.
>> The second part computes the weighted inner product,
>> with each term having the form:
>>       (u,u) = u^T B u / volume
>> where volume := 1^T B 1, with "1" the vector of all 1s,
>> and B being the diagonal mass matrix.
>> In general, in nek, one has
>>       | f g dV = glsc3(f,bm1,g,n)  ,
>> assuming that f() and g() are arrays living on mesh 1.  The
>> array bm1() is the mass matrix B, on mesh 1 (the velocity/
>> temperature mesh - but not the pressure mesh, which is
>> mesh 2).
>> The function glsc3(a,b,c,n) takes the triple inner product:
>>      glsc3 = sum_i a_i b_i c_i , i=1,...,n
>> Note that glsc3 works both in serial and parallel --- the
>> sum is taken across all processors so that you get the
>> correct result on all processors.  If for some reason you
>> desire a local (to a processor) inner product, you would
>> use vlsc3(a,b,c,n) instead of glsc3, which stands for
>> global scalar product, 3 arguments.  We also have glsum,
>> glsc2, glmax, glmin, etc. and of course their local
>> counterparts vlsum, etc.
>> Finally, the third change is to ensure that only node 0
>> writes the result, and not all of the mpi ranks.  Otherwise
>> you have P copies of the results written when running on P
>> processors.
>> Hope this helps.
>> Paul
>> On Fri, 15 Apr 2011, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Neks,
>>> I would like to investigate the mixing of passive scalars in turbulent
>>> flows.
>>> Therefore, I tried to write a function to compute the scalar dissipation
>>> rate. I found someone on the list who did it for temperature and
>>> pressure
>>> so
>>> I tried the same way. Unfortunately, my gradients seem to be zero all
>>> the
>>> time. The code i wrote looks like:
>>>      include 'SIZE'
>>>      include 'TOTAL'
>>>      include 'ZPER'
>>>      include 'NEKUSE'
>>>      common /scalar/ dc1dx(lx1*ly1,lz1*lelt)
>>>     &             ,  dc1dy(lx1*ly1,lz1*lelt)
>>>     &             ,  dc1dz(lx1*ly1,lz1*lelt)
>>>      real scalar_diss
>>>      scalar_diss = 0.0
>>>      call gradm1(dc1dx, dc1dy, dc1dz, ps(1))
>>>        do i=1,lx1*ly1
>>>          do j=1,lz1*lelt
>>>              scalar_diss = scalar_diss + (dc1dx(i, j)**2)*2
>>>              scalar_diss = scalar_diss + (dc1dy(i, j)**2)*2
>>>              scalar_diss = scalar_diss + (dc1dz(i, j)**2)*2
>>>           enddo
>>>        enddo
>>>        write(6,*) scalar_diss
>>> I looks pretty much the same like in
>>> https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2010-November/001106.html.
>>> The fields have all the same size (lx1=lx2=lx3 and so on).  My testcase
>>> is
>>> a
>>> small rectangular grid initialized with the passive scalar set to one in
>>> the
>>> lower half and zero in the upper half. Thus, I would expect some value
>>> about
>>> 2*number of points.
>>> I hope you can help me. I'm struggling with this for some time now, but
>>> could
>>> not find my mistake. Maybe it is just my lack of experience with
>>> Fortran.
>>> Thank you
>>> Alex
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
