[Nek5000-users] Scalar Derivatives / Scalar Dissipation
Fri Apr 15 12:08:14 CDT 2011
Hi Alex,
Here a routine I coded up some time ago to compute the scalar dissipation rate.
Hth,
Stefan
c-----------------------------------------------------------------------
      subroutine scalDisp(chi,Z,D)
c
c    compute scalar dissipation rate
c    chi := D * |grad Z|^2
c
      include 'SIZE'
      include 'TOTAL'
      real chi(lx1,ly1,lz1,1)
      real Z  (lx1,ly1,lz1,1)
      real D  (lx1,ly1,lz1,1)
      common /scrns/ w1(lx1,ly1,lz1,lelt)
     $              ,w2(lx1,ly1,lz1,lelt)
     $              ,w3(lx1,ly1,lz1,lelt)
      ntot = nx1*ny1*nz1*nelv
      call opgrad (w1,w2,w3,Z)
      call opdssum(w1,w2,w3)
      call opcolv (w1,w2,w3,binvm1)
      call magsqr (chi,w1,w2,w3,ntot)
      call col2   (chi,D,ntot)
      return
      end
On 4/15/11, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Alex,
> I'm assuming your call is in userchk?
> There are several items of which you should be aware (mostly related
> to parallel processing, since the code fragment is typically
> being executed on multiple processors).
> First - you should use t(....,2) as the argument to gradm1, if
> you want dissipation of PS1.  (I'm assuming that you're also
> tracking temperature -- otherwise you can store your passive
> scalar in the temperature array.  The data layout is as follows:
>          variable       pointer
>        temperature:    t(1,1,1,1,1)
>        pass. scal 1:   t(1,1,1,1,2)
>        pass. scal 2:   t(1,1,1,1,3)
>            etc.
> You should make certain that ldimt in SIZE is large enough
> to support the desired number of passive scalars.
> Assuming you want to compute dissipation rate for passive
> scalar 1, I would modify your code to read:
>        call gradm1(dc1dx, dc1dy, dc1dz, t(1,1,1,1,2) )
>        n = nx1*ny1*nz1*nelv
>        scalar_diss = ( glsc3(dc1dx,bm1,dc1dx,n)
>       $              + glsc3(dc1dy,bm1,dc1dy,n)
>       $              + glsc3(dc1dz,bm1,dc1dz,n) ) /volvm1
>        if (nid.eq.0) write(6,1) istep,time,scalar_diss
>      1 format(i9,1p2e14.6,' scalar diss')
> OK --- What does this do?
> The first part is as you had it, save that you take the
> gradient of t(....,2), which is where PS1 resides.
> The second part computes the weighted inner product,
> with each term having the form:
>       (u,u) = u^T B u / volume
> where volume := 1^T B 1, with "1" the vector of all 1s,
> and B being the diagonal mass matrix.
> In general, in nek, one has
>       | f g dV = glsc3(f,bm1,g,n)  ,
> assuming that f() and g() are arrays living on mesh 1.  The
> array bm1() is the mass matrix B, on mesh 1 (the velocity/
> temperature mesh - but not the pressure mesh, which is
> mesh 2).
> The function glsc3(a,b,c,n) takes the triple inner product:
>      glsc3 = sum_i a_i b_i c_i , i=1,...,n
> Note that glsc3 works both in serial and parallel --- the
> sum is taken across all processors so that you get the
> correct result on all processors.  If for some reason you
> desire a local (to a processor) inner product, you would
> use vlsc3(a,b,c,n) instead of glsc3, which stands for
> global scalar product, 3 arguments.  We also have glsum,
> glsc2, glmax, glmin, etc. and of course their local
> counterparts vlsum, etc.
> Finally, the third change is to ensure that only node 0
> writes the result, and not all of the mpi ranks.  Otherwise
> you have P copies of the results written when running on P
> processors.
> Hope this helps.
> Paul
> On Fri, 15 Apr 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I would like to investigate the mixing of passive scalars in turbulent
>> flows.
>> Therefore, I tried to write a function to compute the scalar dissipation
>> rate. I found someone on the list who did it for temperature and pressure
>> so
>> I tried the same way. Unfortunately, my gradients seem to be zero all the
>> time. The code i wrote looks like:
>>      include 'SIZE'
>>      include 'TOTAL'
>>      include 'ZPER'
>>      include 'NEKUSE'
>>      common /scalar/ dc1dx(lx1*ly1,lz1*lelt)
>>     &             ,  dc1dy(lx1*ly1,lz1*lelt)
>>     &             ,  dc1dz(lx1*ly1,lz1*lelt)
>>      real scalar_diss
>>      scalar_diss = 0.0
>>      call gradm1(dc1dx, dc1dy, dc1dz, ps(1))
>>        do i=1,lx1*ly1
>>          do j=1,lz1*lelt
>>              scalar_diss = scalar_diss + (dc1dx(i, j)**2)*2
>>              scalar_diss = scalar_diss + (dc1dy(i, j)**2)*2
>>              scalar_diss = scalar_diss + (dc1dz(i, j)**2)*2
>>           enddo
>>        enddo
>>        write(6,*) scalar_diss
>> I looks pretty much the same like in
>> https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2010-November/001106.html.
>> The fields have all the same size (lx1=lx2=lx3 and so on).  My testcase is
>> a
>> small rectangular grid initialized with the passive scalar set to one in
>> the
>> lower half and zero in the upper half. Thus, I would expect some value
>> about
>> 2*number of points.
>> I hope you can help me. I'm struggling with this for some time now, but
>> could
>> not find my mistake. Maybe it is just my lack of experience with Fortran.
>> Thank you
>> Alex
> Nek5000-users mailing list
