[Nek5000-users] istep
Fri Apr 15 07:43:43 CDT 2011
Thanks again,
I just thought there was an easier way and it seemed strange to me that I
couldn't get the cumulative timestep. I don't usually change dt so for now I
just use int(time/dt). And I don't really use fld files ;-), since we
already have a fantastic inhouse visualization software (
http://persons.unik.no/andershe/papers/voluviz/voluviz.html).
Best regards
Mikael Mortensen
The Norwegian Defence Research Establishment (FFI)
2007 Kjeller
Norway
On 15 April 2011 14:15, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mikael,
> I'm going to make a note of your request - it's not supported
> now, but could be w/ a bit of effort.  The effort would be relatively small
> for the .fld files, a bit more for the .f0000 files, which is a newer
> feature.
> Generally I handle this issue by changing the name, e.g.,
> myrun_1a.rea
> myrun_1b.rea
> myrun_1c.rea
> etc.
> In /tools/scripts/ the scripts mvv and cpn make it easy
> to do this --
>   cpn myrun_1a myrun_1b  copies all the requisite files.
>   mvv does the same except with move.
> Although it seems like a look a good idea to have the feature you're asking
> about, there are some pitfalls - namely, if you change the order midstream
> in a sequence of runs then Visit/postx
> will be unhappy processing the sequence.
> If I wish to process a long sequence of .fld or .f files, I usually
> ln them to a common base name (e.g., "myrun") using a script that
> can be cooked up in about 30 seconds.  I then process the lot.
> Paul
> On Fri, 15 Apr 2011, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi,
>> Just a very short (probably stupid) question. When restarting a case it
>> seems to me that the istep parameters is reset to zero, which leads to new
>> fld files overwriting the old. For example, if I run 10 timesteps and
>> store
>> blah.fld01 - blah.fld10 I then put blah.fld10 like this in the rea
>>           1 PRESOLVE/RESTART OPTIONS  *****
>> blah.fld10
>> And then I ask for 10 more timesteps by setting p11 to 10 in the .rea
>> file.
>> I would expect to get 10 new fld files blah.fld11 - blah.fld20, but
>> instead
>> my blah.fld01 - blah.fld10 files are overwritten. Should it be like this?
>> Is
>> there some parameter or similar that one has to make sure to specify when
>> restarting to avoid this?  Is there a cumulative istep I don't know of?
>> Thanks and best regards
>> Mikael
>>  _______________________________________________
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110415/b1ea00de/attachment.html>
