[Nek5000-users] istep
Fri Apr 15 04:30:13 CDT 2011
Ok, thanks
Mikael
On 15 April 2011 11:19, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mikael,
> It's not a bug - it's a feature.
> Typically, I move my fld into a new folder (e.g. run01, run02, ...) to
> avoid that my data gets overwritten. Why do you want to get a single
> fld-file set for different runs? Anyway, one way to do this is to use
> a shell script creating a set of symbolic links. Here an example:
> foo.fld01 -> run01/foo.fld01
> foo.fld02 -> run01/foo.fld02
> foo.fld03 -> run02/foo.fld01
> foo.fld04 -> run02/foo.fld02
> Hth,
> Stefan
> On 4/15/11, nek5000-users at lists.mcs.anl.gov
> > Hi,
> > Just a very short (probably stupid) question. When restarting a case it
> > seems to me that the istep parameters is reset to zero, which leads to
> new
> > fld files overwriting the old. For example, if I run 10 timesteps and
> store
> > blah.fld01 - blah.fld10 I then put blah.fld10 like this in the rea
> >             1 PRESOLVE/RESTART OPTIONS  *****
> > blah.fld10
> > And then I ask for 10 more timesteps by setting p11 to 10 in the .rea
> file.
> > I would expect to get 10 new fld files blah.fld11 - blah.fld20, but
> instead
> > my blah.fld01 - blah.fld10 files are overwritten. Should it be like this?
> Is
> > there some parameter or similar that one has to make sure to specify when
> > restarting to avoid this?  Is there a cumulative istep I don't know of?
> > Thanks and best regards
> > Mikael
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20110415/9d37ee53/attachment.html>
