[Nek5000-users] heat transfer in a channel
Fri Sep 17 12:51:47 CDT 2010
I'm running a DNS of fully developed heat transfer in a channel, the same as
H. Kawamura et. al, International Journal of Heat and Fluid Flow, 1998.
I use following subroutine to get rid of additional heat
c-----------------------------------------------------------------------
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ie   = gllel(ieg)
      qvol = -vx(ix,iy,iz,ie)
      source = 0.0
      return
      end
Other procedures are similar to turbChannel example.
But I find the mean temperature is not correct,  there should not be
negative  value in my case.
I attached my *.usr and *.rea and means.dat to this email.
is there any one  else did DNS of heat transfer in a channel ?
Thank you very much
zhicheng
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100917/83091fb4/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100917/83091fb4/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100917/83091fb4/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100917/83091fb4/attachment-0002.obj>
Type: application/x-ns-proxy-autoconfig
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100917/83091fb4/attachment.dat>
