[Nek5000-users] element order range
Tue Sep 14 11:25:45 CDT 2010
Hello All.
I am doing some tests of Nek5000 against a low-order code.  Under "Performance tips", it is recommended to "design your resolution (mesh) for N=7 or N=9"
Are there any limitations on the range of values for N?  For example, what is the smallest N and largest N that the code can/has been run with?    What are the limitations with running at, say, N = 16?
Thanks.
--Mike
