[Nek5000-users] Planar averaging in 2D
Fri Oct 8 19:12:00 CDT 2010
For non-tensor products you would need to use the interpolation
routines.
Paul
On Fri, 8 Oct 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Does this routine work for non-tensor product domains ? I had been wanting
> to do spatial averaging in nek for non-tensor product domains, but haven't
> found a way yet.
> Regards
> Shriram Jagannathan
> On 8 October 2010 09:48, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi David,
>> The attached routine was written for planar averaging in y --
>> Have a look - it should in principle work in 2D as well.
>> Note that it's not been tested in 2D or 3D as far as I know.
>> I wrote it for someone a week or two ago (with the same
>> caveat).  Am posting to the user list in case someone knows
>> if this is working or has been tested/fixed.
>> Paul
>> On Fri, 8 Oct 2010, Aleksandr Obabko wrote:
>>  Hi David,
>>> You are correct -- planar_avarge_z has to be modified.  I'm finishing the
>>> report today so after it I can make a pass at the routine.
>>> Best,
>>> Aleks
>>> On Fri, 8 Oct 2010, David Goluskin wrote:
>>>  Hi Aleks,
>>>> A few months ago, you told me how to get horizontally averaged
>>>> temperature
>>>> profiles using the planar_average_z routine.  To get horizontal averages
>>>> for
>>>> a 2D run, I am guessing I need to either modify the planar averaging
>>>> routine
>>>> or change the vertical coordinate form y to z, which I don`t know how to
>>>> do.  What do you suggest?
>>>> Thank you,
>>>> David
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
