[Nek5000-users] Planar averaging in 2D
Fri Oct 8 18:16:48 CDT 2010
Hi Paul,
Does this routine work for non-tensor product domains ? I had been wanting
to do spatial averaging in nek for non-tensor product domains, but haven't
found a way yet.
Regards
Shriram Jagannathan
On 8 October 2010 09:48, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi David,
> The attached routine was written for planar averaging in y --
> Have a look - it should in principle work in 2D as well.
> Note that it's not been tested in 2D or 3D as far as I know.
> I wrote it for someone a week or two ago (with the same
> caveat).  Am posting to the user list in case someone knows
> if this is working or has been tested/fixed.
> Paul
> On Fri, 8 Oct 2010, Aleksandr Obabko wrote:
>  Hi David,
>> You are correct -- planar_avarge_z has to be modified.  I'm finishing the
>> report today so after it I can make a pass at the routine.
>> Best,
>> Aleks
>> On Fri, 8 Oct 2010, David Goluskin wrote:
>>  Hi Aleks,
>>> A few months ago, you told me how to get horizontally averaged
>>> temperature
>>> profiles using the planar_average_z routine.  To get horizontal averages
>>> for
>>> a 2D run, I am guessing I need to either modify the planar averaging
>>> routine
>>> or change the vertical coordinate form y to z, which I don`t know how to
>>> do.  What do you suggest?
>>> Thank you,
>>> David
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101008/5312d84f/attachment.html>
