[Nek5000-users] Temperature Issue, non physical values for certain Pr num.
Wed Nov 17 23:21:12 CST 2010
I am having an issue with temperature values in my domain. The domain consists of two inlets, one at a temperature of 300 and the other 100. It appears
that the interface between the two is giving non-physical temperatures, but what is interesting is the magnitude of these over/under shoots is dependent on
the Prandtl number.  To see the extend of this I saved the max/min temperature in the domain for several time steps.
See the attached image.  The low Pr case had Pr = 0.005, where as the other case had Pr = 0.71.  Both cases show non - physical results, but the low Pr
case seems to recover and approach the limits for the domain given by the boundary conditions.  In the other Pr = 0.71 case, the fluctuations and magnitudes are
much larger and don't appear to stabilize and recover.
Again, I have looked at fld files to confirm that these large differences occur at the interface between the hot/cold fluid.  Is there a solution to this problem?
Michael
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101117/94e8e14d/attachment.html>
Type: image/tiff
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101117/94e8e14d/attachment.tif>
