[Nek5000-users] Data output
Thu May 20 06:16:04 CDT 2010
Yes that's correct!
The I/O format is controlled by the following rea-file parameters:
input: param(67)
output: param(66)
Use negative number for ASCII else it will be BINARY.
In some cases param(66)/param(67) is hardwired in the usr-file.
In this case they're set to 4 to work with the _old_ BINARY format (needed for prex).
I strongly recommend the new BINARY format because it gives you the best performance and a lot of features are only supported in this mode!
Stefan
On May 20, 2010, at 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Well I have been using .fld files because I just cannot remember how to switch to .f???? :-[
> Including the right CB, I should have the following userchk subroutine:
> subroutine userchk
>       include 'SIZE'
>       include 'TOTAL'
>       include 'RESTART'
>      ifreguo = .true.
>       return
>       end
> Is that correct ?
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100520/4cfc316a/attachment.html>
