[Nek5000-users] [*] Re: Data output
Thu May 20 05:31:54 CDT 2010
     param(66) and param(67) should be changed to 1 if you want to use
.f????. Also make sure these values are not changed in userchk file. In
some examples these two parameters are set to 4 and I find that nek then
outputs in fld format.
Cheers,
Mani chandra
On 05/20/2010 03:20 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Well I have been using .fld files because I just cannot remember how
> to switch to .f???? :-[
> Including the right CB, I should have the following userchk subroutine:
>     subroutine userchk
>           include 'SIZE'
>           include 'TOTAL'
>           include 'RESTART'
>          ifreguo = .true.
>           return
>           end
> Is that correct ?
> Nek5000-users mailing list
