[Nek5000-users] [*] Re: Visit messing up
Thu May 20 04:39:56 CDT 2010
Is this the output of high_ray01.f0001? In this case there is no geometry (coordinates) in your fld-file (there is not X in the variable encoder only UPT).
Stefan
On May 20, 2010, at 11:36 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
>    I'm using 43 files.
> Output of  head -n1 foo.fXXXX | strings
> #std 4  5  5  5      37632      37632  0.1000000000000E-02         1      0      1 UPT
> Attached is the database file. It contains
> NEK3D
> version: 1.0
> filetemplate:  high_ray%d.f%04d
> firsttimestep: 1
> numtimesteps: 43
> Mani chandra
> On 05/20/2010 02:50 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Are you using just a single fld-file?
>> Please post your visit meta-data file (e.g. visit.nek5000) and the output of
>> to get the ASCII string at the very beginning of your first fld-file.
>> Stefan
>> On May 20, 2010, at 11:19 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi,
>>>    Sometimes, randomly visit messes up the visualization, as shown in the attached picture. The mesh is supposed to be that of a 3D box. Reloading the database does not work. The simulation seems to be going ok and nek is running fine. I'm using Visit 1.12.2 svn revision 9638 and nek svn revision 518. Any clue as to why this is happening?
>>> Thanks,
>>> Mani chandra
>>> <mesh.jpeg><Mail Attachment.txt>
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> <vis.nek3d>_______________________________________________
