[Nek5000-users] prex & pretex not working
Sat May 15 03:41:18 CDT 2010
The unknown compiler handling is fixed in the latest release.
Stefan
On May 15, 2010, at 5:16 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> this is in response to Harish's mail from Mon May 3 13:14:48 CDT 2010.
> Not sure if your problems are solved now, but I had similar issues on a Fedora 12 machine with gcc/gfortran 4.4.3-4.fc12, where prenek would compile fine (with BIGMEM=true) but would just get killed after startup of prex (the window pops up shortly, but vanishes without displaying anything).
> I could fix it by updating to and compiling with gcc&gfortran-4.5. Using new gfortran and older gcc4.4.3 resulted in the same error.
> @Developers: Further, I think the reason for not getting any output from the maketools is the following lines in "maketools", where I assume the echo and exit calls should be exchanged in order (and a typo) to get a clean output (at least on my system nothing showed for an unknown f77 compiler).
>  *)           exit 1
>               echo "Error: Unkown compiler!"
> to
>  *)           echo "Error: Unknown compiler!"
>               exit 1
> Markus
> Nek5000-users mailing list
