[Nek5000-users] perturbing interior variables
Tue May 11 17:40:41 CDT 2010
Hi Frank,
Yes.
You can call dsavg() on each timestep and you'd be ok.
It simply projects the solution onto the space of continuous
functions.   If it's already there, then it won't change
anything.
Note, if you are doing conjugate heat transfer or have
a problem with a different topology for u and T (e.g.,
periodic bcs for u but not for T), then you would need:
       ifield=1
       call dsavg(vx)
       call dsavg(vy)
       call dsavg(vz)
       ifield=2
       call dsavg(t)
In 99.9% of all cases run with Nek, however, you can ignore this
last comment.
Paul
On Wed, 12 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
> On Tue, 2010-05-11 at 17:14 -0500, nek5000-users at lists.mcs.anl.gov
wrote:
> Hi Frank,
> Yes - any function that is supposed to be continuous should be
> so at timestep 0, else there will be problems.
Hi Paul,
But if one is perturbing the velocity and/or temperature not at t=0 but
at a later time (in "userchk") then "dsavg" should still be called?
Cheers,
Frank
> For the Pn-Pn-2 formulation, pressure is discontinuous, so there
> is no issue for pressure in this case.
> However, one would call dsavg for vx, vy,vz and T ---
> This is already done in ic.f following standard initialization
> procedures.
> It likely wouldn't need to be done if you range strictly over
> the element interiors, i,j,k \in [2,...,nx1]^3 --- but it
> wouldn't hurt in any case.
> Paul
> On Tue, 11 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
> > Hi Paul,
> I'm not quite sure what you mean here, am assuming you have in mind
> continuous across element boundaries.  At present, some simulations are
> running where at a certain time, the temperature field is perturbed as
> in the code segment below.  Would the absence of "dsavg" cause a problem
> regardless of whether one loops from "k=2,nz1-1" or "k=1,nz1" etc.?
> Also, is "dsavg" needed when dealing with velocity?
> Cheers,
> Frank
>        if(time>1. .and. time<= 1.+2.5*dt)then
>        write(*,*)'Symmetry breaking'
>        vmax=.01 ; tmax=.99 ; radius=1.5 ; radius_s=.25
>        nlocations_perturbed=3
>          do 100 iel=1,nelv
>          do 100 k=2,nz1-1
>          do 100 j=2,ny1-1
>          do 100 i=2,nx1-1
>            do n=1,nlocations_perturbed
>            angle = acos(-1.)*2.*(n-1.)/nlocations_perturbed
>            x1=radius*cos(angle) ; y1=radius*sin(angle)
>          if(((xm1(i,j,k,iel)-x1)**2
>       &    + (ym1(i,j,k,iel)-y1)**2
>       &    + (zm1(i,j,k,iel)-.45)**2)**.5.le.radius_s)then
>             t(i,j,k,iel,1)=tmax*t(i,j,k,iel,1)
>          endif
>            enddo !n
> 100     continue
>        endif  !time>1. .and. time<= 1.+2.*dt
> On Tue, 2010-05-11 at 07:38 -0500, nek5000-users at lists.mcs.anl.gov
> wrote:
> > Hi Frank,
> > One additional note.
> > It's important that your perturbed T() be continuous.
> > This could be done, e.g., via the following code in userchk
> >         if (istep.eq.0) then
> >            n=nx1*ny1*nz1*nelt
> >            do i=1,n
> >               t(i,1,1,1,1) = t(i,1,1,1,1) + perturbation of choice
> >            enddo
> >            call dsavg(t)
> >         endif
> > The dsavg() will ensure that T is continuous.   If T is not
> > continuous at the beginning, it will be discontinous forever
> > since we only solve for delta T and then add this to T.
> > Paul
> > > Hi Frank,
> > > Boundary values will be set by userbc().
> > > There is no opportunity to intercede between userbc() being called
> > > and the solver.  (In effect, userbc() _is_ the opportunity to
> > > intercede.)
> > > userchk is called at the end of each step and therefore effectively
> > > at the beginning of the next.  Perturbing there will work - you can
> > > perturb all values and rest assured that values on Dirichlet surfaces
> > > will be overwritten by userbc.   Values on Neumann surfaces, however,
> > > would not be reset by userbc.
> > > hth,
> > > Paul
> > >> Thanks for the replies, Aleks and Stefan.  I am still not clear on one
> > > point though.  Are changes made to temperature or velocity on boundaries
> > > in "userchk" at each time step irrelevant since they are overwritten by
> > > calls to "userbc"?
> > > Cheers,
> > > Frank
> > > On Mon, 2010-05-10 at 18:15 +0200, nek5000-users at lists.mcs.anl.gov
> > > wrote:
> > >> The heat solver calls BCDIRSC which will apply Dirichlet bcs. All 't  '
> > >> boundary points call userbc so you have the full control over the values at
> > >> the boundary.
> > >> Stefan
> > >> On May 10, 2010, at 6:00 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > >> > Hi Frank,
> > >> > > > I assume that you refer to t(i,j,k,iel) as temperature -- to be safe
> > >> it should be t(i,j,k,iel,1)...
> > >> > > > In timestepping loop, subroutine userchk is called last by one --
> > >> right before the last one -- prepost which dumps field files .f or .fld --
> > >> see nek5_svn/trunk/nek/drive1.f:
> > >> > >      DO ISTEP=1,NSTEPS
> > >> >         call nek_advance
> > >> >         call userchk
> > >> >         call prepost (.false.,'his')
> > >> >         if (lastep .eq. 1) goto 1001B
> > >> >      ENDDO
> > >> > > while, as I can see, userbc for a passive scalar is called from a chain
> > >> of subroutines nek_advance > heat > cdscal > BCNEUSC/BCDIRSC
> > >> > > This means that perturbation of temperature at the boundary won't be
> > >> overwritten in userbc.
> > >> > > > One way to apply perturbation everywhere including the element faces
> > >> that are not on the boundary of your domain is simply to multiply your
> > >> perturbation factor by a function that goes to zero on the boundaries,
> > >> e.g.:
> > >> > >   t(i,j,k,iel,1)=.99*t(i,j,k,iel,1)*(xm1(i,j,k,iel)**2.-1.)
> > >> > > in case the boundary surface plane is at x=1 & x=-1
> > >> > > Best,
> > >> > Aleks
> > >> > > > > > > > On Mon, 10 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
> > >> > >> Hello all,
> > >> > > I am trying to perturb the temperature in a small part of the flow.
> > >> > However, I only wish to perturb in the interior and not on a boundary.
> > >> > I have the following in "userchk".  If I instead looped from "k=1,nz1"
> > >> > instead of "k=2,nz1-1", would this change the BC's?  The general
> > >> > question would be, does changing uvw & T in "userchk" change BC's or
> > >> > does "userbc" override what is done in "userchk"?
> > >> > > Cheers,
> > >> > Frank
> > >> > >        do 100 iel=1,nelv
> > >> >        do 100 k=2,nz1-1
> > >> >        do 100 j=2,ny1-1
> > >> >        do 100 i=2,nx1-1
> > >> >        if(((xm1(i,j,k,iel)-1.1)**2
> > >> >     &    + (ym1(i,j,k,iel)-1.1)**2
> > >> >     &    + (zm1(i,j,k,iel)-.45)**2)**.5.le..25)then
> > >> >           t(i,j,k,iel)=.99*t(i,j,k,iel)
> > >> >        endif
> > >> >          enddo !n
> > >> > 100     continue
> > >> > > > > > -- > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> > >> > Technische Universität Wien (Technical University of Vienna)
> > >> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> > >> > Mechanics and Heat Transfer)
> > >> > Resselgasse 3
> > >> > 1040 Wien
> > >> > Tel: +4315880132232
> > >> > Fax: +4315880132299 Cell:+436765203470
> > >> > fmuldoo (skype)
> > >> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> > >> > > _______________________________________________
> > >> > Nek5000-users mailing list
> > >> > Nek5000-users at lists.mcs.anl.gov
> > >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users_______________________________________________
> > > Resselgasse 3
> > > 1040 Wien
> > > Tel: +4315880132232
> > > fmuldoo (skype)
> > _______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
