[Nek5000-users] Compilation failing with gfortran
Tue May 11 05:08:38 CDT 2010
     I'm using mpif77 with gfortran underneath and I'm not able to
compile any of the examples of the latest code (which I downloaded today).
The error is:
/home/guest/nek5_svn/trunk/nek/navier8.f: In function 'setvert3d':
/home/guest/nek5_svn/trunk/nek/navier8.f:2322: internal compiler error:
in expand_expr_real_1, at expr.c:6846
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
make: *** [obj/navier8.o] Error 1
However an earlier version of the code which I've been using for a
couple of months works fine. Attached is the compiler.out. I've noticed
that the input files are slightly different. Do we not need SESSION.NAME
any more?
Mani chandra
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100511/e232fe75/attachment.ksh>
