[Nek5000-users] History points
Wed May 5 15:17:21 CDT 2010
Hi Jean-Christophe,
This examples forces Nek5000 to output into the file blah.sch a time trace (H) of pressure (P), x & y velocity components (UV) for a point located in the element w/ global number IEL and collocation coordinates I,J K.
Use 'grep History logfile' to get coordinates of the points.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Wednesday, May 5, 2010 12:22:03 PM GMT -06:00 US/Canada Central
Subject: [Nek5000-users] History points
Hello Nek's,
I have a few questions on how to use the history points.
I have seen on the wiki the following stuff:
History points
Specify grid points to monitor the specified variables in time. Example: ***** HISTORY AND INTEGRAL DATA *****
1    POINTS.  Var, Hcode, I, J, K, IEL
             UV P    H    2  2  1  4
NOTE:
    • Make sure LHIS in SIZEu is large enough
I bet Var stands for variable, but what do Hcode, I, J, K, and IEL stand for ?
Once you have specified the location of your history point, let's say a point on the centerline of a stenotic flow at whatever streamwise station, how do you get the data concerning this history point? Do you have to change anything else in the output specification section ? I have tried to add the wiki lines up there directly in my blah.rea but once I ran the code I did not get any new files other than the expected blah.fld's.
Jean-Christophe
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
